![]() ![]() Join Date: Nov 2012
Interesting VINs
Anybody got any interesting VINs like '00001, '1234567, or '77777 ? How about a really low number, or really high? Four of a kind? Full house?
Re: Interesting VINs
There was a 61 here about two months ago that was 000007
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
GMC's n H.D.'s too!
![]() Join Date: Oct 2010
My VIN is 1047. According to Jolly's GMC site, that makes it #46 built in 1960.
I have an "H" in my vin for factory code. As far as I know H does not exist for factory codes. Could be a type. Sould check the actual VIN to my title, ins. cards, and registration.
Glenn |
"H" is a Fremont, Ca built truck. Mine is an "H" also.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
![]() Join Date: Aug 2008
Thats right "h" is a cailf truck they called it oakland then iN 65 made it a "z" which is fremont
1961 crewcab
at one point I had 2 1960's that were within 500 of each other, both from the oakland plant.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
built in oakland was a O. H when they moved to fremont and Z from 65 on? my 61 k10 is an O and my 56 nomad was an O.
1961 chevy K10 my build is------------61K10 build |
Not a vin number, but I found a 250 inline 6 cylinder that was only 92 engine numbers apart from the original 250. Had to be built the same or next day, and must have been delivered to the same area as my truck. Maybe even to the same dealership, on the same car carrier! My truck was built in Atlanta and delivered to (IIRC) Westminster SC. I found the engine and truck in Anderson SC within a few months of each other.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
my k61 was a late build?-vin------11925
![]() Join Date: Aug 2010
Not a Vin, but I recently discovered that my OG '66 was built on my birthday. I know it's not a big deal for anybody but me, but I still think it's cool!
#12 | |
#13 |
1961 crewcab
-take the 1 off, it was 1925 built at that plant.
my 26 t was built on my birthday, but 56 years earlier, I found the production date on a body brace
#14 |
forgot a 1--my vin is 111925 didn't they start at 100001?
#15 |
GMC's n H.D.'s too!
The GMC's (I don't know about the Chevy's) started at 1001.
Here is the page on Jolly's site about VIN's. http://www.6066gmcguy.org/VinNumber.htm |
#16 |
1961 crewcab
yes, then your first post is correct, 11925.
#17 |
jonz---so this is a high build for 61? funny it had a 62 hood on it with the right neptune green. and thanks for your expertise!
#18 |
1961 crewcab
def. a higher build #, but not sure what total production was for 61....
as the supply of 61 hoods ran out, the new 62 hood was used for replacement of damaged hoods, this might even pertain to a late production 61 truck? very likely that the hood was damaged at some point and replaced with the 62 hood. ..also the 62 hood was designed for better frontal visibility, so there is a chance, especially since yours was the taller 4X4 that the original owner(s) opted to try out the new hood..
#19 |
if the VIN starts with H it is a heavy duty truck, I got a title for one of my cabs, a 1/2 that started with H, and the data plate was off of a 25,00 GVW truck. I cut up the cab because ther data plate had been switched
Steve |
| Bookmarks |
