Old 11-07-2012, 01:44 PM   #1
lapaipaxxx
Help with fuel pump issues
I have a 86 c10 with LY6/4L80e. Returnless style. Recently truck would shut off while driving, but would start right back up again. Have had that issue for like a month. One day it just would not start, so i figured it was a bad fuel pump due to fuel starvation since tank does not have baffles and decided to replace it. Went ahead and ordered new ac delco ep381, 87 baffled fuel tank and installed them.
After installation truck turned couple of times before starting. Took it for a 10 min drive truck ran fine didnt seem to have any issues then came back home shut off truck and tried to restart. Truck did not start. Pump will not prime, so i replaced relays and checked ground but nothing. I dont know what else to check for.
I would appreciate any help with this issue
Thanks,
Jesse
lapaipaxxx is offline   Reply With Quote
Old 11-07-2012, 02:17 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Help with fuel pump issues
you don't mention anything about your fuel filter?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-07-2012, 04:11 PM   #3
lapaipaxxx
I have a fuel filter/reg 33737 wix. I have not changed that yet. Do you think that has something to do with fuel pump not prime.
Old 11-07-2012, 06:17 PM   #4
68GMCCustom
if your old tank had something in it...and the lines then yes...it could have gotten clogged (not saying it did tho). No prime...where's the pump?
Kurt -
Old 11-07-2012, 07:36 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x2, wheres the pump located?
What your describing sounds like you have too much height or length before the pump and the pump can't draw hard enough so you cavitate and starve.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 11-07-2012, 08:56 PM   #6
lapaipaxxx
Pump in tank with an 87 sending unit
Filter is right about 1 1/2 foot from tank
Could a clogged filter burn out the pump?
Old 11-08-2012, 12:07 AM   #7
ls1nova71
ls1nova71's Avatar
A clogged filter will definitley put a strain on a pump, and probably could cause it to fail over time, but I don't think it would do it that fast. Have you verified that you actually have power going to the pump at the sender? Checked grounds, especially where thwe tank/pump is grounded. Also I have seen the hose between the pump and sender blow off or get a hole in it and the pump will be running but not build pressure.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 11-08-2012, 08:54 AM   #8
lapaipaxxx
Thanks for that info, but how do I check to see if the pump has power.
Old 11-08-2012, 10:57 AM   #9
awhite4557
awhite4557's Avatar
I would start by testing at the relay for power. Connect a test light to the pump side of the relay and have someone turn the key to "on". The relay should have power for a few seconds before it turns back off. If you have power there, then connect the test light to the terminal/ wire at the pump and check it again. The test light should come on for a few seconds and then cycle off. You should also be able to hear the pump run for a few seconds when you turn the key to "on" as well. If you have power and the pump runs, disconnect the fuel line after the filter, unhook the wire to the pump and connect an external 12 volt source to the pump and check your fuel flow. Use a short hose and run the fuel into a clean container for re-use and let it run for a while to see if the pump stops or flow is low. You may also want to check the wire size going to the pump and check for amp drop. That will cause the pump not to work as well. If all works well, connect a fuel test gauge to the fuel rail to make sure you have adequate pressure at the rail.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 11-08-2012, 12:25 PM   #10
Wasted Income
Boosted Member
Wasted Income's Avatar
I've had to replace at least 2 of those WIX "filter/regulators" that were f'n junk right out of the box.
My bet is on the filter/regulator.
What's the fuel pressure while running?
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-10-2012, 10:46 AM   #11
lapaipaxxx
well i think i have found the problem. fuel pump works but no power at wiring harness after rechecking wires and relays found this. Pretty sure its the problem i just need to replace harness. anybody know where to buy both fuel pump and sender harness.
Old 11-10-2012, 12:55 PM   #12
68GMCCustom
a ground issue cause that?
Kurt -
