11-07-2012, 08:23 PM | #1 |
My dirty dingo motor mounts
Here's some pictures ...... you won't be able to use the factory ac bracket with these mounts... Dirty dingo does sell a bracket to move the ac up on the passengerside tho...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
11-07-2012, 08:40 PM | #2 |
Re: My dirty dingo motor mounts
Those are very nice.. I had a set, but did not work out for me.. Mine was a 4wd... I am sure they will work out fine for you..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
11-08-2012, 03:29 PM | #3 |
what year engine(water pump) is that... i am used to seeing the water heater outlet houses go horizontal... those appear to be vertical...... hmmmm please advise.
oh .. nevermind... i see ... it is the angle.. sorry
11-08-2012, 04:49 PM | #4 |
What engine stands are you using? Have you set the motor in the truck yet? How much room do you have in the back of the motor?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-08-2012, 06:05 PM | #5 |
The stands are performance online tubular mounts. I haven't put the engine in the truck as of yet, but these mounts will let the engine move up to 3" so i won't have to have my 3.5" aluminum driveshaft re cut and welded....
11-08-2012, 07:52 PM | #6 |
Truck and auto performance nut
I like those mounts but must have missed them when I installed my motor. I may swap to them if I ever have to pull the motor. They use a better design SBC motor mount...with the long thru bolt.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-09-2012, 12:51 PM | #7 |
Boosted Member
I used the Holley plates with solid "SBC" style mounts on my NoLimit crossmember for my K/5.
Made plates and used the stock engine mount towers, and stock truck style motor mount on my C-10.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2016 Ford Explorer Sport - Twin Turbskis 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-09-2012, 01:30 PM | #8 |
Can you post the part numbers for the POL stands and the dirty dingo mounts? I found the mounts for 73-87, but not 67-72. Thanks in advance.
11-09-2012, 05:31 PM | #9 |
The dirty dingo slider sbc to ls1 lsx conversion engine swap mounts. They don't have a part number... The performance online frame mounts is
ECM6372C. May have to call them because i'm not sure if they include the polyurathane upper mounts or not... The upper mounts i have are the short and wide energysuspension part numbers 355-3-1114g. Hope all this works... should tho... You can see the pol mounts that i used with the big block... I'll try to get some better pics tomorrow....
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 Last edited by 69trk; 11-09-2012 at 05:38 PM. |
11-09-2012, 05:34 PM | #10 |
Boosted Member
The slider concept is interesting. Looking forward to hear how it all fits.
11-29-2012, 07:47 PM | #11 |
Finally got motor in. Mounts work great. Wont have to change driveshaft.
Posted via Mobile Device Posted via Mobile Device
11-29-2012, 08:11 PM | #12 |
I have the sliders and used them in my 6.0 suburban 4wd swap and although the ac compressor fits and they say that it does they did not mention at the time you had to notch the frame which i have no interest in doing so i just took mine off, good design aside from the cold weld and my cousin had the exact same set the first post shows and had porosity in two of the welds
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
11-29-2012, 09:29 PM | #13 | |
R/
11-29-2012, 10:24 PM | #14 |
I'll get you a picture and measurement tomorrow... Not sure on headers yet. I think i want the foreward and downward facing headers but still looking at clearance issues with ac compressor moved up on passenger side and ps pump. If i can't get them to work i will just use the truck manifolds facing foreward and have the v-bands welded on and have them jet hot coated...
11-30-2012, 07:00 PM | #15 | |
12-01-2012, 09:10 PM | #16 |
Here u go .
12-01-2012, 09:19 PM | #17 |
Thanks! How much further could you slide the engine back, if you wanted to?
12-01-2012, 09:29 PM | #18 |
At least 2". I would like to slide it back further but if i do i would have to have driveshaft cut...
12-03-2012, 04:09 PM | #19 |
Boosted Member
Yikes! When i had air ride, I bottomed my truck out hard. Cracked the oil pan....AND the bellhousing on the 4L80E. Might want to re-consider using a truck pan. The 4th gen f-body pan fits real nice. $.02
05-02-2013, 09:47 AM | #20 |
Has anyone done a diy slider? I'm looking into making my own adapter plates now and I'm thinking about going this route, but the price tag is a bit high for me.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
05-02-2013, 12:28 PM | #21 |
I used there sliders on my '72 suburban. However I used 73+ engine frame stands with the 73+ sliders from dirty dingo. I was able to put the 6.2/6l80e combo in slid all the way forward without cutting the driveshaft. Even the th400 tranny mount worked. Just slid the tranny crossmember forward and drilled new holes for it and bolted to the frame. The stock truck tranny shift linkage is really close. Just a hair off. Will probably work, but may bind so I need to modify it slightly.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
05-02-2013, 01:03 PM | #22 |
looks like the pan that came with my LY6...I probably should change it now...but plan is to wait for IFS upgrade and/or dis-assembly for paint and body work.
05-02-2013, 09:11 PM | #23 |
i used the same mounts in the forward holes expect i used the factory 71 mounts on the sliders
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-04-2013, 10:23 PM | #24 |
There's been a lot of discussion about the quality of these mounts. It'll be interesting to see how they holdup.
05-05-2013, 09:51 AM | #25 |
Not sure what you guys are talking about on these mounts... They are thick metal plates that slide with bolts.... There is nothing to break on these... I'm more worried about the polyurathane part of the motor mount which is not dirty dingo...
