11-08-2012, 01:18 AM | #1 |
C/10 junkie
WTB 5 lug axles
I know this is probably a long shot but I'll give it a try. I am looking for a set of 5 lug axles or conversion axles for my 68 rear end. They obviously need to be for the narrow rear end. Let me know what you have and how much shipping would be to a 95240 business address. Please respond in thread.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
11-08-2012, 09:52 AM | #2 |
Re: WTB 5 lug axles
I have a set..... I'll just need to make sure they're the right size. I actually have two sets. do you know how long they need to be?
ORTEGAMOTOR |
11-08-2012, 10:06 AM | #3 |
C/10 junkie
Re: WTB 5 lug axles
Actually I don't but I know they are shorter than the later 70-72 axles and I have a set of those so let me measure them and we will go from there. I'm guessing since the early axle housing is 1 1/2" short then the axle should be 3/4" shorter?
11-08-2012, 10:55 AM | #4 |
Re: WTB 5 lug axles
I looked at mine (Moser, for the late rear end) and they are 31 5/16 "
.. but the Moser for the early rear end shows 30 1/2 " Adding 3/4 per side that's within 1/16". 30.5 + .75 = 31.25 (31 1/4") I will tell ya, when I put the pin back in mine , the tolerances were spot on. You couldn't get it any closer. Just a light bump to get the pin to go back between the axle ends, but you could push it back out with your finger. It was definitely not as loose as with the original 6 luggers. So, I'm thinking the shorties are 30.5" long per side. That help? Running stock 5 lug axles, you should be really close with 30.5" Mosers are $260 + bearings and seals. Just FYI.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
11-08-2012, 11:02 AM | #5 |
C/10 junkie
Re: WTB 5 lug axles
Thanks Chad that helps a bunch. Where did you buy your Mosers from? Tony what do your axles measure?
11-08-2012, 11:39 AM | #6 |
Re: WTB 5 lug axles
Ordered mine straight from MEng. Super happy with them. 1/2 in studs, just FYI.
11-08-2012, 12:17 PM | #7 |
C/10 junkie
Re: WTB 5 lug axles
Is 1/2 studs the stock size and do they come with lug nuts?
11-08-2012, 12:27 PM | #8 |
Re: WTB 5 lug axles
Hey Shawn and Chad. Got a question for y'all. I recently measured the rear end on my '70 C10. Turns out, it's the wider one. I plan to do the five lug swap too so would Shawn's longer set work for me (assuming you're looking for the shorter set as a replacement)?
11-08-2012, 12:38 PM | #9 |
C/10 junkie
Re: WTB 5 lug axles
Yes and no. For you the swap will be easy, just find a 71-72 5 lug rear end and steal the axles. I have the early 6 lug rear end which is narrower to start so I need a set of aftermarket conversion axles. Sorry I can't help you there.
11-08-2012, 01:56 PM | #10 |
Re: WTB 5 lug axles
You'd need the longer version axles. (same as mine Chris) Stock / Aftermarket .. either way. Same legth.
7/16 is stock Shawn. 1/2 is usually Ford. My truck is all 1/2 now. So, saying if you do Mosers you will likely need new lugs too.
11-08-2012, 01:57 PM | #11 |
Re: WTB 5 lug axles
Lug nuts sold seperately.. Some assembly required.
(studs are pressed in when you get them too)
11-08-2012, 02:21 PM | #12 | |
67-72 parts collector,…
Re: WTB 5 lug axles
1/2" is stock for 71-87 5-lug trucks.
11-08-2012, 02:29 PM | #13 | |
C/10 junkie
Re: WTB 5 lug axles
11-08-2012, 04:47 PM | #14 |
C/10 junkie
Re: WTB 5 lug axles
I found this on the Summit website, looks like I need the 30 1/2" axles.
http://www.summitracing.com/parts/ms...del/c10-pickup
11-08-2012, 04:55 PM | #15 |
Re: WTB 5 lug axles
Yep.. they're sweet man.
11-08-2012, 05:49 PM | #16 |
C/10 junkie
Re: WTB 5 lug axles
Will the stock bearing work? I just put in new seals and bearings and would hate to buy new ones if I didn't have to.
11-08-2012, 06:02 PM | #17 |
Re: WTB 5 lug axles
Yeah.. if theyre new, Id think youre good. The ones I got from Moser were just Napa bearings. Id say theyre just stock spec but maybe call and ask to be sure?
11-08-2012, 06:15 PM | #18 |
C/10 junkie
Re: WTB 5 lug axles
I will, thanks Chad. Tony put down the wrenches for a moment and take a measurement
11-09-2012, 02:24 PM | #19 |
C/10 junkie
Re: WTB 5 lug axles
ttt looking for a pair of 30.5" 5 lug axles
11-09-2012, 03:05 PM | #20 |
Re: WTB 5 lug axles
Most shorties out there will all be 6 lug. Id say if they are short 5 lug, theyre likely aftermarket.
11-09-2012, 03:40 PM | #21 |
C/10 junkie
Re: WTB 5 lug axles
Yeah I'm almost positive they are gonna be aftermarket, I was just hoping to catch someone maybe going a different direction with their build or ordered the wrong set or just wanting to help a brother out.....
11-09-2012, 03:42 PM | #22 |
Re: WTB 5 lug axles
Buy my 68 step. It has some in it. . 3:73 too...
11-09-2012, 03:47 PM | #23 |
Re: WTB 5 lug axles
I got my mosers for short diff at Summit Racing.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
11-09-2012, 03:47 PM | #24 |
C/10 junkie
Re: WTB 5 lug axles
I just sold my 3.73 gear set No chance of parting that thing out, huh??
11-09-2012, 03:58 PM | #25 |
Re: WTB 5 lug axles
Dude I totally dropped the ball. I just ran out to the shop to measure those axls they look to be 30.5 I think thats what you're looking for . PM me for info and my #
Tony
ORTEGAMOTOR |
