Old 11-08-2012, 02:20 AM   #1
hpcgmc
hpcgmc's Avatar
A question for the rattle can guys
I just rattled can painted my whole truck in primer gray. I used primer because I intend to get the truck painted in a year or two, and this will make it look presentable while I work on suspension, engine, etc. This is my first major foray into paint of any kind, and especially a full vehicle rattle can. I don't want to spray a top coat of a finish spray paint, as I was told at a paint shop that this would make it much more difficult to paint when I'm ready for the real thing.
The primer scratches pretty easily, seems to rub off pretty easily, and seems to hold dirt and greasy hand marks. Should I try to wax this to keep it from rubbing off and resisting scratches? If I wax it, should I go over it with a very light sandpaper first?Should I just leave it as is? Here are the before and after pics. I'm pretty happy with how it turned out.
Thanks for any ideas.
1967 GMC 1500 SWB. Driving this truck since I was 14.
hpcgmc is offline   Reply With Quote
Old 11-08-2012, 03:11 AM   #2
orange rumble
orange rumble's Avatar
Re: A question for the rattle can guys
I would'nt wax a primer job,just keep it washed and wiped down on a regular basis,and hit scratches ,nicks and **** with your rattle can whenever you feel like it.Later down the road when your ready for a durable paint job,it's going to be easy to sandblast it down to metal so you can start your body work,fillin holes etc.
orange rumble is offline   Reply With Quote
Old 11-08-2012, 03:19 AM   #3
orange rumble
Keep it washed and touched up untill your ready to take it down to metal and start from the beginning.
Old 11-08-2012, 05:25 AM   #4
bk2life
not being a jerk, and if it sounds that way it is not intended, but:
1. It’s good for a quick looks change (your truck looks good)
2. Will need to come off for paint
3. If you wax it, forget about painting it
4. What is your budget for your upcoming paint job?
5. Spend a little more and get higher quality primer and spray it from a gun.
6. It is not “durable” and will scratch/lift/rub off
bk2life is offline   Reply With Quote
Old 11-08-2012, 06:13 AM   #5
Square_78
Square_78's Avatar
Yeah primer from a rattle can will have to be completely stripped off before real paint is applied. You may as well throw a top coat of color on there or a satin black or something.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-08-2012, 08:53 AM   #6
cobra_4
cobra_4's Avatar
Yeah the body shop is gonna have to sand that back down anyway unless your going to Mayco. Might as well do what you want with it color wise, but I defiantly wouldn't wax it!
cobra_4 is offline   Reply With Quote
Old 11-08-2012, 10:20 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Agree with all above posts. I did a similar thing to my truck years ago with the intentions of painting it later. Due to economic circumstances I was unable to paint it and surface rust set in. As I found out, primer I used was porous and let moisture in.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-08-2012, 11:12 AM   #8
hpcgmc
hpcgmc's Avatar
Thanks for the input. The paint shop guys told me this rattle can primer was porous and would let moisture in, so not to let it sit more than a year or so. They recommended a spray gun primer, but I don't have anywhere to spray it. Here in Cali, if i spray outside, I'm sure to have problems (I live in a neighborhood). I've considered going to Maaco or some place similar just to have them do a spray gun primer - might still look into that.
Old 11-08-2012, 11:20 AM   #9
cdowns
cdowns's Avatar
for thee price and the protection stability and overall looks it is hard to bet the maaco solution for a tight budget
