Can't figure out what type of transmission I have
I have a 1964 chevy c10 with a 292 engine backed by a 3 speed manual - I cna't figure out for the life of me what type it is - Can you walk me through this problem - I would like to either replace it or at least replace the gaskets that appear to be leaking but I'm stuck not knowing what to buy???
Who Me?
Re: Can't figure out what type of transmission I have
Can you show us some pics of it?
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Most likely its a muncie mc318 or a saginaw.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Here are a few pictures of my transmission taken from under the truck - not very clear
muncie mc318. Parts are still available for these transmissions
Heres a pic of one cleaned up
This link doesn't list every possible transmission, it's a good reference for identifying the more common ones ... http://www.roadkillcustoms.com/hot-r...tification.asp
My truck ain't dead, it just smells funny. |
Thanks for the help - The transmission works fine it just leaks oil from the filler plug and the driver side panel (as you can see from the picute) - What is the best way to solve these two problems? - also a small leak at the rear seal / shaft
Gasket kits are still available, and that will help the side cover. Might try some teflon tape on the plugs.
