Chevy 350 4 bolt main Max HP
So I have recently found out thankfully that my motor isn't a Chevy 350 its a Chevy 305 thats a 2 bolt main, which thankfully I found all this out before I started dropping serious cash trying to get mad torque and hp out of it.
What my question is, is what is the Max HP you can get out of a Chevy 350 4 bolt main, safely and still if I wanted to have it as a daily driver I could. Note this its not an LS1 motor its a Crate Chevy 350. Any advice or help will be perfect just trying to make a game plan for my motor that I'm going to have to buy.
Korwin 77 C10 Silverado Sharkbite LWB Build 67 Chevy C10 Frame Off 06 Dodge Magnum 2.7v6 aka swag wag! 2010 Honda Accord 2.4I4 DD aka Liquid Metal |
BAD BOW-Silverado XST
Re: Chevy 350 4 bolt main Max HP
For daily driving and carbed? 300-350 is high end IMO. Any higher and performance motors eat gas.
Okay, well I doubt it'll ever be driven daily mainly car shows and such. Let me ask it this way could I hit 600hp carbed?
I have time, i'm not trying to hit 600hp overnight it's going to take time.
It's tough to have a streetable N/A 406 with 600hp, even a 383 is going to take cash and will require a lot of maintenance. Even then, it won't be a long lived engine.
Stroke a 454 to 496, pocket ported heads with big valves and a healthy hydraulic roller will get you there and not need anything but regular oil changes. Now add forced induction and you're talking about a completely different animal. |
I hear you there. Well reason I'm asking is like it says I found out my motor is actually a 2 bolt main 305 which wont hold crap. So I started looking into pricing on a new motor, well a Chevy 350 turn key is about $4,700, I can get an LS1 for $5,100, with that being said I'll probably try for the LS1 being that its an aliuminum black and that motor is made for racing and it can handle anything I can throw at it.
go twin turbo ls1
1969 chevy camaro Z28 #matchin Factory 4wheel disc 1969 chevy cst10 big block overdrive 5/7 drop dog dishs 1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s 2004 gmc sierra dually 4/4 lowering daily driver |
Will I be able to cause the compression is already a 10.25:1
If you're going LS and plan to hammer hell out if it, forget the aluminum blocks, start with a 6.0L iron block and add a pair of L92 yeads and stroke it to low 400 cubes. It'll take all you can throw at it including big boost and spray. They're the block of choice for folks that don't want to spend what it takes to get an LSX block.
Yeah I'm going to run the hell out of it, it's mainly a play toy that's going to be more shown that anything but still be used to take out and cruise and things like that I'm not planning to just have it balls to the walls all the time
The iron 4 bolt main will handle 600 hp on a factory block. A two bolt main iron factory block that's got a splayed 4bolt and half hard block will handle 700hp these are in naturally aspirated form.
Superchevy has made a 1000hp turbo small block but I don't know the details since it was forever ago There are two ways to make big hp livable as a street engine. One is with cubic inches and the other is with boost. And by livable I mean you not wanting to stab yourself after a five mile highway stretch Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#13 |
Wow! But I mean with a LS1 I should be able to put up those kind of numbers too huh?
