Old 11-08-2012, 01:40 PM   #1
rmccloye
rmccloye's Avatar
Red face Rear End Gears
I currently have 4.10 rear end gears in my truck. I live in a pretty hilly part of AR. Anyone have any idea what gear size is right? How does 3.08 gears, 3 on the tree w/2.94 first gear and 29.5 inch tires sound?
I'm not a heavy foot driver by the way
rmccloye is offline   Reply With Quote
Old 11-08-2012, 02:35 PM   #2
Indian113
Indian113's Avatar
Re: Rear End Gears
I'm pretty sure you will need a different carrier with 3:08's. With the one you have now there's a limit on the size you can change too. I have 3:73's with a 700 R4 and love the way it works. I'm just going by what I've been told I could be misinformed.
Indian113 is offline   Reply With Quote
Old 11-08-2012, 02:37 PM   #3
1963c-10
1963c-10's Avatar
Re: Rear End Gears
4:10's are in the 4th series carrier. I think the 3:08's are 3rd series
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-08-2012, 07:28 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Rear End Gears
I have 26" tall tires, 3.08 gear and TH350 tranny. Usually with an 4 speed OD tranny, my gear would be good for the highway. With only a 3 speed, its kinda low for the highway.. I plan a taller rear tire next round to make that gear seem a little taller.
Not sure if that helps.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-08-2012, 08:21 PM   #5
ol_skool_chevy
ol_skool_chevy's Avatar
Re: Rear End Gears
I will assume your running a V8, what RPM are you running at 55MPH with your 3:73 and 700r4? tire size will make a sort of differace also but i didnt see you list that....
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 11-08-2012, 10:36 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Rear End Gears
With a 4 series carrier, 373 is the tallest gear you can go. Do you have 6lug or 5lug?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-08-2012, 10:43 PM   #7
Indian113
Indian113's Avatar
Re: Rear End Gears
Yes I have a mild 350,28 inch tall tires. I have no idea what my RPM's are as I don't have a Tach. I can tell you I rarely run 55 as I drive a lot on 4 lanes and 65-70 feels a lot like 55 did with the 350 trans I had.
Old 11-09-2012, 09:54 AM   #8
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Rear End Gears
it would help if you told us why you want to change.
actually, if you're not going to be driving interstate speeds then I'd think the 4.10s would be fine for those hills. 3.08s wouldn't be as good for pulling hills. 3.73 would probably be better, all around.
what year truck is it (looks like a '64-'66)? makes a difference if it's a '60-62, I think, as to the ratios available, because it wouldn't be a "12 bolt".
you can play around with the gear calculators here:
http://www.wallaceracing.com/Calculators.htm
Larry
fleetsidelarry is offline   Reply With Quote
Old 11-09-2012, 10:11 AM   #9
luvbowties
luvbowties's Avatar
Question Re: Rear End Gears
My guess is that given the terrain you describe, with a 3.08 you'd be in 2nd gear a lot. Hills and 3-speeds should be much happier with 3.73 than with 3.08.
luvbowties is offline   Reply With Quote
