Old 11-08-2012, 02:59 PM   #1
ulakovic22
Wilwood Master Cylinder
Will a Wilwood manual master cylinder for a disk/drum brake system bolt up to the firewall in place of the factory MC without any modifications? I see a lot of people using them, but I don't see any pics or comments suggesting they had to do anything special to install them. Thanks!
Edit: I have a 1967 truck that has been converted to 5 lug, disk/drum using 71-72 suspension. I currently have no hydrualic brake components at all, aside from wheel cylinders and calipers. No lines, valves, MC, etc.
ulakovic22 is offline   Reply With Quote
Old 11-08-2012, 03:58 PM   #2
Portmod7
Portmod7's Avatar
Re: Wilwood Master Cylinder
I had to improvise the rod between the pedal and master cylinder, but other than that it bolts right up.
I used a threaded tube, threaded onto the master cylinder pushrod, and a heim joint at the other end of the tube and bolted to the pedal. I'm not sure what everybody else is doing.
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 11-08-2012, 04:13 PM   #3
ulakovic22
You just used the bottom two studs on the firewall for install? What did you use for a prop valve? Factory on the factory bracket with custom lines from the MC to valve?
Old 11-08-2012, 05:32 PM   #4
Portmod7
Portmod7's Avatar
Yep.
I didn't use a proportioning valve. I tried to stagger the piston area in my calipers so I wouldn't need one. I wouldn't really recommend doing it that way. Most guys just run an aftermarket valve in the line to the rear brakes. And I may end up doing it that way myself depending on the braking performance I get once I finally get it on the road.
