Engine numbers help please!
I tried to research them but I wasn't having much luck.
This engine is in my 69 C10 , its supposed to be the original 350 that was in the truck. These are the numbers located at the front passenger side of the engine, but you experts all ready know that. I read there is some numbers on the back of the head on the driver's side. I need to clean that area up, someone spilled gasket adhesive all down that area. I can see a ???114 maybe, its tough to tell. ![]() ![]()
Toys/projects Many toys, not enough time to play! My youngest son and I picked up a 69 Chevy C-10 on 1/7/22, this is my second 69, it was 10 years ago that I had my other one. So I知 back!!! ![]() |
Re: Engine numbers help please!
Thanks Geezer, I will check it out.
#4 | ||
"I ain't nobody, dork."
This is what "CDB" translates to:
CDB 1972 350 Powerglide, Calif L65 - 2 A B/Monte CDB 1982 267 Roch E2ME carb. J L39 - 2 B G Check the casting number on the back of the block on the drivers side in front of the bellhousing. Hope for it to be... 3970010. Then it would be a 350. You say it might be XXXX114? Sure the last 3 might be 014? That would be a 350 as well. You really don't want it to be the cruddy 267. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Wow, this is confusing, takes a bit to figure out .
So far the easy part, the engine code V0315CDB Means V = made in Flint 03 = March, the 3rd month 15 = 15th of the month However CDB means ?? The engine vin 12C173624, does not match at all to my truck vin, so numbers aren't matching!!! Which they should for a 1969 correct? So where did this engine come from?!?!?! I will try to get my casting numbers. Thank goodness for camera phones, makes it a whole lot easier to simply squeeze your hand to the location 10 or 20 times until you get the best / clearest picture...lol
Thanks Gasoline, I forgot to respond to your post in my previous post, sorry about that.
Do you think the CDB means maybe its a 72 and came with the 350 powerglide trans? I will go get the casting number, I'm sure that will help, I hope.
#7 | ||
That's what the number you posted says. But now you need to look at the casting number on the back of the block located on the drivers side rear... just in front of the transmission bellhousing.
Gary
On A matching numbers motor the last six digits on the pad match the last six on your vin.
In your case the numbers 173624 are the ones that should match. |
Thanks Gary and Geezer,
![]() It has a build clock ![]() My vehicle vin ![]() I was going to decipher, but I have a client that just showed up, back in a few to decipher what I can.
#10 | |
Our trucks did not have frame numbers stamped on the block. Cars of the era (67-72) did but trucks did not. Your motor came out of a passenger car, and from the CDB code it came from a 72 or 82 impala or chevelle. If it's a 72 then it's a 350. if it's a 82 then it's a 267. I bettin on the 72. Grab that casting number. I use the camera trick alot cause I'm too old to crawl across the motor ![]()
CHEVY/GMC VIN DECODERS |
i think all of the early truck blocks did not have the vin stamped on them
Thanks Bruce,
I think you just missed it. Its 3970010 Which could be a 1968 327 or I think and hope its a 1969-79 350, How do I tell if its 2 bolt or 4 without taking it apart?
#13 |
Good shot, it's a 72 350. the 010, 350 block is the most desireable, due to a high nickel content. You can't tell 2 or 4 bolt without dropin the pan and lookin.
#14 |
I love the clock markings, but can't they have the minute as well
![]() ![]() It looks like the 10th hour of the shift (hope they weren't to tired) How about the other marking the shift maybe, it shows a D N T, I'm thinking Day shift, Night shift, whats the T if they are doing 10 hour shifts? Also there is a 3 down below the clock area, 3rd mold maybe? ![]()
#15 |
Thanks Bruceman!
#16 |
Think we can narrow it down even more with the engine vin 12C173624 ?
#17 | ||
You have a 350. Not much more to it than that. You have a very good foundation for an engine in that truck.
![]() Gary
#18 |
The 010 in the casting number does not signify the nickel content. If there is a 010 or a 020 or both under the timing chain cover that is supposedly the better block.
Bud |
#19 |
Yeah the 3970010 is probably the most common number for a 350. They put that number in everything. I have pulled that number out of wagons, moving vans, campers, trucks, vans and cars. The 4 bolts were put in the heavier of vehicles. If you could find a cube van with a 2 barrel, most likely it was a 4 bolt.
