Old 11-08-2012, 10:34 PM   #1
mikesacs
mikesacs's Avatar
Air Conditioning choices
I'm looking for an evaproator and heater combination for my suburban. It needs to have both heat and A/C, work with the dash controls, and be able to keep my glove box. I don't need the compressor and condensor.
I've looked at Classic Auto Air and it looks pretty good. Any alternatives or advice?
mikesacs is offline   Reply With Quote
Old 11-09-2012, 01:05 AM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Air Conditioning choices
Vintage Air gen4.
LT1 Burb is offline   Reply With Quote
Old 11-09-2012, 01:21 AM   #3
Z POPPY
I agree. Well made, great quality and well written directions. Vintage Air gen4. Only problem you do some of the glove box, about a 1/4 of it. A new glove box is supplied. Specify what controllers you need. Deluxe or regular.
http://www.vintageair.com/semanpchevygmcpup.gasp
Z POPPY is offline   Reply With Quote
Old 11-09-2012, 03:46 AM   #4
Z POPPY
Pictures of my 64' with Vintage Air gen4 completed inside the cab.
Old 11-09-2012, 07:11 AM   #5
brokenspoke
brokenspoke's Avatar
Originally Posted by LT1 Burb View Post
Vintage Air gen4.
X 2 on Vintage air..... search my postings and see my install
brokenspoke is offline   Reply With Quote
Old 11-09-2012, 09:30 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Ill agree with Vintage Air.
I have Vintage Air, which works great, but! I like the look of the VA and mine is also 12 years old too, things have changed drastically in the 12 years.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-09-2012, 12:21 PM   #7
mikesacs
mikesacs's Avatar
I do like the looks of the Vintage Air unit. Does anyone know if it is better quality than the Classic Auto Air? Anyone with Classic Auto Air experience?
If I went with Vintage Air, would I need a overhead rear unit to assist since this is a suburban.
Old 11-09-2012, 12:56 PM   #8
Clyde65
Clyde65's Avatar
I would suggest you speaking to each vendor and inform them what your putting this into. most burbs of the era prior to say 75, they would put an AC unit under the rear seat.
Clyde65
Rebuild of Clyde
support our troops!
Old 11-09-2012, 01:04 PM   #9
newbe351
Isn't the GMC glove box different than the Chevy? Will the insert fit both GMC and Chevy?
newbe351 is offline   Reply With Quote
Old 11-09-2012, 02:01 PM   #10
mikesacs
mikesacs's Avatar
I don't want to mount one to the floor since I need to be able to remove the seats for hauling stuff. I only have a 2/3 wide seat in the back and it doesn't have an inch of space under it.
Old 11-10-2012, 02:18 AM   #11
Z POPPY
Don't know if the Chevy and gmc are the same in the glove box insert. Duct hoses are why it's smaller. When I ordered my full AC kit it specified 1964-1966 Chevy trucks. So each unit is a semi-custom application. That also includes choices in AC brackets locations of compressor. BBC and SBC.
Back to our original poster Mikesacs
I would suggest you call vintage air. Discuss what you want and what your looking for. I bet they have a solution for you.
at*(800) 862-6658*or*(210) 654-7171*
Old 11-10-2012, 04:21 PM   #12
Slow Build
Slow Build's Avatar
Do all the aftermarket AC/heating systems use only recirculated air?
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 11-10-2012, 05:26 PM   #13
brokenspoke
I know my VA does....I suspect all do
Old 11-10-2012, 08:25 PM   #14
rustbucket66
I have just finished installing the unit I have from Old Air Products. I was impressed with the kit. It sacrifices about 3 inches of the back of the glove box, so you still have a good sized glove box. It also uses the stock heater control housing, so there isn't a separate panel for the controls. For the most part the instructions were good, and it wasn't too painful to install.
rustbucket66 is offline   Reply With Quote
Old 11-11-2012, 12:30 PM   #15
'65Burb
What about keeping the original unit. Will they work with modern condensers and coolant?
'65Burb is offline   Reply With Quote
Old 11-11-2012, 02:55 PM   #16
Clyde65
Clyde65's Avatar
Old Air does too, also Old Air doesnt have foot board heat only out of vents.
Clyde65
Rebuild of Clyde
support our troops!
