Old 06-02-2003, 09:26 AM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Steering column bottom bearing
I got the tilt column torn down just so I could replace the signal switch. I thought I may as well replace the bottom bearing while I am at it. This is one of the goofiest bearings I have ever seen and it even has an o-ring in the center where the steering shaft comes through. Has anyone found a suitable replacement for this bearing? Thanks
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 06-02-2003, 02:01 PM   #2
crazy4chevs
crazy4chevs's Avatar
I need one also!
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 06-02-2003, 02:49 PM   #3
onelow69
onelow69's Avatar
I bought my lower bearing from ECE for my tilt about a week ago. It cost around 15 bucks. Just don't break the plastic carrier that the bearing rides in. Good Luck.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
