Old 11-09-2012, 01:36 PM   #1
BLUE SQUARE
BLUE SQUARE's Avatar
Kick Panel Install (Need Help)
Hey Gents-
I recently purchased these Kick Panels for my truck(See Link Below) from 73-87 chevy trucks.com.
I want to Glue Them so that there's no screws showing. Has any body here used these - How did you install these. Also, What kind of glue do you reccomend? I don't want my kick panels to come apart. Thanks for your help.
http://store.73-87chevytrucks.com/me...y_Code=7387INT
BLUE SQUARE is offline   Reply With Quote
Old 11-09-2012, 01:48 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Kick Panel Install (Need Help)
most of the ones I see people use is a total replacment panel with that molded in
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-09-2012, 02:11 PM   #3
BLUE SQUARE
Yeah, and Q-Forms has some decent ones if you're running components. I decided to go this route because I'm running 6.5 (Three Way) Infinity Kappas 6.39i up front. I have the matching 6x9s in the rear Infinity 6.93i with the Brackets provided from Jeff (BigBlock 73).
Old 11-09-2012, 11:35 PM   #4
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I just used 3 black torx head screws on each side of mine a bit longer than factory going thru mine and the factory panel to the metal to hold mine in place.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 11-10-2012, 09:55 AM   #5
Fan2zee
Fan2zee's Avatar
I was able to use factory rubber seals and attachments for clean installation.
87' R10
Fan2zee is offline   Reply With Quote
Old 11-10-2012, 09:56 AM   #6
Fan2zee
Fan2zee's Avatar
Driver Side
87' R10
Old 11-10-2012, 12:31 PM   #7
trivon56
trivon56's Avatar
Where and what type of kick panels you have.
Originally Posted by Fan2zee View Post
Driver Side
trivon56 is offline   Reply With Quote
Old 11-10-2012, 12:48 PM   #8
Fan2zee
Fan2zee's Avatar
Q-logic, 87 C10/R10
87' R10
Old 11-12-2012, 01:10 PM   #9
BLUE SQUARE
Yea- I ended up just using some screws which I painted black to match the kick panels. I will post pictures tonight.
Your kicks look good Fan2zee.
Old 11-12-2012, 02:29 PM   #10
Fan2zee
Fan2zee's Avatar
Thanks.
87' R10
Old 11-12-2012, 09:02 PM   #11
88Jimmy4x4
88Jimmy4x4's Avatar
Driver Side
does the e-brake still function w/o hitting the speakers?
1991 GMC Jimmy 4x4
Old 11-12-2012, 10:36 PM   #12
Fan2zee
Fan2zee's Avatar
With the E-brake engaged, the pedal stops about a 1/4" before it would hit it. I've had the kick panel speakers installed for almost a year, and I thought maybe after the E-brake wore down in year it may start hitting. Still all good, with zero modifications.
87' R10
Old 11-14-2012, 11:47 PM   #13
BLUE SQUARE
Here are some pictures of the kick panels that I installed.
Old 11-15-2012, 12:07 AM   #14
BLUE SQUARE
Here are a few more pics of the overall install.
Old 11-15-2012, 06:46 AM   #15
Fan2zee
Fan2zee's Avatar
Clean Truck, looks good.
87' R10
Old 11-15-2012, 07:34 AM   #16
Skunksmash
Skunksmash's Avatar
Looks real good. But I got big feet so those things would bother me. I think I'm mounting in the door carpets like some people do.
Skunksmash is offline   Reply With Quote
Old 11-15-2012, 12:53 PM   #17
BLUE SQUARE
Yeah, Thanks. I still need to detail the interior, but it's still a work in process. I have alot left to do to the interior.
I need to build a box for my sub, replace the carpet, replace the bench seat, and replace the dash.
Old 11-17-2012, 07:57 AM   #18
Fan2zee
Fan2zee's Avatar
I found this sub-box enclosure that met my dimension specs, and then all I had to do was make an amp board to match. Seat still goes all the way back and reclines all the way.
87' R10
Old 11-18-2012, 11:57 PM   #19
BLUE SQUARE
That's a clean install. I think I'm going with the JL tw5 and I will just build a box to house the sub and two jl amps. We'll see how it goes. I'll keep you posted.
BLUE SQUARE
Old 11-19-2012, 03:15 AM   #20
Big-Sexy907
Where can I find some of these?
Big-Sexy907 is offline   Reply With Quote
