11-09-2012, 01:49 PM | #1 |
Filled drip rail pics
I know there has to be a ton of drip rail post...But, can you guys post your filled not shaved pictures. I just want to make my drip rail flush and looking for ideas how to do it.-Thanks!
11-10-2012, 09:07 AM | #2 |
and a few others
Re: Filled drip rail pics
Do you mean fill in the channel? I did that on my 63. I used Duraglass.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
11-10-2012, 09:10 AM | #3 |
Yes the channel.. Have any pics of yours?
11-10-2012, 09:51 AM | #4 |
and a few others
I don't have any pics where you can really see the channel. And I sold this truck a while back. But, the channel repair wasn't really noticeable to an untrained eye.
Here's one pic. I would suggest, if you're gonna do it don't use Bondo because it will crack when applied thick. I used Duraglass first, then feathered it with Chromalight. My channels were just in such bad shape, this was just an "easy" fix since I painted it flat anyway.
11-10-2012, 08:45 PM | #5 |
Senior Enthusiast
Here’s what I did to mine. After grinding the roof gutter cavity to bare metal and coating with epoxy primer, the lower portion of the rain gutters were filled up with Evercoat Maxim self leveling seam sealer. One huge advantage to this product is that it uses a standard caulking gun. Now instead of water sitting in a trough with no drain, it just flows over the edge preventing future rust damage. These are the best photos I have to offer:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
11-11-2012, 08:25 AM | #6 |
1961 crewcab
I guess this one is more shaved than filled....
I was thinking of using some small metal rod around the edge of mine to get a sharper edge, and then more rod in the gutter, and the duraglass method to feather it out.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-12-2012, 12:41 AM | #7 |
60-66 Nut
I don't remember who it was but another member had a good idea on filling the drip rails. After he cleaned the channels out good, he tack welded a 1/4" round rod in the channel all the way around. This way there was less filler needed and less of a chance of an issue. I don't remember if he used body filler or seam sealer. IMO seam sealer is the way to go. The seam sealer that markeb01 used appears to be holding up well.
11-12-2012, 05:45 AM | #8 |
"Where were you in '62?"
I'll take some pictures after work today.
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
11-13-2012, 11:11 AM | #9 |
Mine at this time.
11-13-2012, 12:43 PM | #10 |
There was another member who cleaned his up, and rolled it over--looked pretty clean!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
