11-09-2012, 02:34 PM | #1 |
"GO DAWGS"
Tach repair
Has anyone sent off one of these tachs for repair. I have one that I cannot get to work and I think it is a bad resistor in the board but cannot find anyone local that will fool with it. I know there are several places that work on and restore these but the price is outrageous. Just checking to see if anyone knows of anybody that fools with these that will not charge an arm and a leg.
Thanks PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
11-09-2012, 07:02 PM | #2 |
Re: Tach repair
Subscribing......
Cheers - Wayne Our Shop Build - http://67-72chevytrucks.com/vboard/s...d.php?t=620966 '55 Wagon Build - http://67-72chevytrucks.com/vboard/s...d.php?t=689157 1971 Cheyenne Super Ochre/White LWB 350 Auto - my son's truck "Nancy" 1972 GMC K2500 Custom 4X4 Olive LWB 400 SB 4-speed -"Greenie" - Restoration to begin after the '55 Nothing sucks more than that moment during an argument when you realize you're wrong. |
11-09-2012, 08:43 PM | #3 |
Re: Tach repair
Also subscribing, my tach quit registering more than 2,100 - 2,200 rpm. Otherwise works fine. Interested to know who can diagnose and repair at resonable $$. Good luck, PT
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
11-09-2012, 08:50 PM | #4 |
Re: Tach repair
Just FWIW, I have a repro tach in mine and they're relatively cheap and look very good (one of the few reproduction parts I'd say that about). Always an alternative... and you don't need to toss your original, just hang onto it.
11-09-2012, 10:12 PM | #5 |
"GO DAWGS"
Re: Tach repair
Ironhorse take your tach out and move the needle to make sure it is not hanging up on the face plate. I have seen this happen alot when the plate gets bent out a little the needle will make contact with the plate and not move any further. You can also take the face plate off and where the needle moves inside that metal block is magnified and it will pick up debris and cause the needle to stick. You can buy a can of compressed air like you would use to clean you pc key board and blow that area out. Just a few things you can try to see if it will fix your problem.
PT
11-09-2012, 10:54 PM | #6 |
Re: Tach repair
Anyone have a tach they believe is registering too high of an RPM reading? I think mine is. 3:73 and a 700r4 with 28 inch tall 15 inch whells and I am reading about 4,000 rpm at 70 mph?
11-09-2012, 11:25 PM | #7 |
Re: Tach repair
Mine reads too high. Turns out I've got a 6 cylinder tach and I'm running a V8. You may have the same problem based on your info.
11-09-2012, 11:45 PM | #8 |
Re: Tach repair
PT, thanks for the tip. Will look at that possible problem. Can't really tell right now as the engine, transmission, and transfer are out for a manual to auto swap. Sounds like something to check into for sure, thanks again for that one.
11-09-2012, 11:48 PM | #9 |
Re: Tach repair
yea chevykevy 4000 rpm for 700r4 and 3.73 is to high mine runs around 2200-2300 at that speed with same setup
11-10-2012, 03:33 PM | #10 |
Re: Tach repair
PT, sorry for robbing your thread. Just thought we have similiar subject matter so figured I would join in.
Just put the tach dash in last week out of a 68. The tach says V8 on the rear and appears to be pretty accurate at idle. I may hook up an aftermarket tach I have and check it out. |
11-10-2012, 07:30 PM | #11 |
Re: Tach repair
I hear these guys are the best out there for repairing and restoring your gauge clusters. Seen that a few members that restore them send them off to this company. One of the members that sells the restored ones, I think send them off to them. Can't be for sure on that, but it seems to be what I read.
http://www.redlineg.com/redlineg/Welcome.html
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
11-11-2012, 08:41 AM | #12 |
DND Trucks
Re: Tach repair
PT,
What's wrong with the tach? What are symptoms? You mentioned the possibilty of a bad componet. LMK, curious. Dave. |
11-11-2012, 10:22 AM | #13 |
"GO DAWGS"
Re: Tach repair
The tach will not do any thing. Checked the ground the ground wire and looked for any burnt spot. I did talk to a guy that does TV and PC repair and he said that when the resistors go bad they usually swell up but do not see any that look abnormal.
PT
11-11-2012, 02:33 PM | #14 |
DND Trucks
Re: Tach repair
You need to determine if it's a meter or board problem. Do you own a multi meter that can read ohms? If so, there's a black and white wire on the board going to the meter assembly. Take your multi meter and select the lowest setting in ohmic value it has and read between the 2 wires. If the tach needle deflects upward, the meter is good. Don't worry if it deflects downward, just switch your leads and watch the tach deflect upward. The point is checking the tach meter field.
Checking each component on the board is more involved. However, a simple visual inspection of the board can reveal things, i.e., leaking caps, open diodes, etc. Using your meter again, check for cold solder joints on every connection, very common problem. These are a few basic examples that you could start with. I could write an essay on this stuff and not cover it all. I'll leave that to someone else. Hope this helps you. Dave. |
11-11-2012, 02:42 PM | #15 |
70+ ( Old Skool Club )
Re: Tach repair
I calculate you should be around 2200RPM at 70mph with that combo.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-11-2012, 02:48 PM | #16 |
member #16
Re: Tach repair
I had a 70 elcamino tach repaired by Bobs speedometer in MI. They did a good job at a reasonable price.
http://www.bobsspeedometer.com/1/120/index.asp
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
11-11-2012, 10:54 PM | #17 |
Re: Tach repair
Already Gone,
Thats what I'm thinking too. I hooked up an aftermarket tach and as soon as the weather breaks I'll check it. I wonder if I'm getting interference from another wire or the tach needs recalibration. |
