Old 11-09-2012, 03:31 PM   #1
jlsanborn
jlsanborn's Avatar
What headers for lowered 4 speed?
I've read TONS of threads on here regarding header clearance and still don't know which is best for my setup or if I should do something different.
'67 C10 which was originally an I6 column shift. I'll be installing a small block onto that same bell with the cross member. I've gotten a floor shift column so all that jazz will be gone. I'm static dropped with 2-1/2" spindles, 2" springs and have a 235/60-15 tire. Rear will likely end up -7 with a 26" tire. I am going to "port" the trailing arm cross memeber to get the exhaust through there but I don't want the collectors draggin.
Is there a kick-azz header that will work or am I looking at switching to a trans cross memeber and / or hydraulic clutch?
Thanks!!!
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
