Just double checking before I go any further.
I have an 85 chevy 305. The oil pressure sending unit should be right behind the distributor right? I'm in the process of rebuilding and just want to make sure I get this thing as close to right as possible the first go 'round. I checked the forums here and most info. I found said it was behind the distributor, on the drivers side. The block I have has no current sender on it, and there is a filler plug in that location(machine shop filled it in). Does anyone have any pictures showing exactly where the unit should go? Also, does this motor need a knock sensor? And where does the knock sensor go?
Re: Just double checking before I go any further.
my 305 has it behind the distributor
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
Thanks, I appreciate it. I'm just a little worried about the exact location, but I guess theres only one spot where it would fit.
It goes right there
![]() 1985 C10 2004 Avalanche |
Thanks I really appreciate it.
