11-10-2012, 01:38 AM | #1 |
Franks'62burb4x4conversion
Heres what she looked like at first . A '62 GMC 2x4 Burb.
with 305 V-6, and a Muncie 4 speed. the donor chassis a '74 3/4 ton 4x4, camper special i had for years |
11-10-2012, 01:41 AM | #2 |
Second Chance Program
Re: Franks'62burb4x4conversion
Going to stick with the v6?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
11-10-2012, 02:11 AM | #3 |
The '74 4x4 chassis (which is a GMC) had a SBC 400, but i swapped that out for a BBC 454 (which came out of a '78 GMC Suburban i scrapped)
For some reason I ALLWAYS end up getting GMC's, not chevys ,,,, My '73 prerunner Blazer... A GMC! just worked out that way. Anyway I shortened the frame 17" AND Zee cut it up, in the front or down in the rear to better match contour of older floor/body. Result; no big gap between cab and forward to core support! i reused some old frame channel to fill in top and bottom gaps. which completely isn't shown. the bottom of frame got filled in and I will "box" in the back. '62 now sits on 4x4 chassis nicely |
11-10-2012, 02:46 AM | #4 |
what do you know? RUST! so get out the wheel of death and start cutting!
deeper and deeper i go. It ends up not much was left of rockers. replace both sides, up the A pillar a little way, and floor pieces. Now i see theres a complete front floor panel available... wish i had that when i started. i just kinda widdled what was gone and used floor "patch" panels |
11-10-2012, 02:54 AM | #5 |
more to remove
then start adding |
11-10-2012, 03:01 AM | #6 |
more coming along.
11-10-2012, 03:15 AM | #7 |
so i decided..off road truck, needs off road safety, plus i had to attach the old body to the newer chassis anyway, why not full cage it? ..2" chromoly tubing.
i plan on using this truck to tow and/or use it on the trails, chase vehicle at races. |
11-10-2012, 03:18 AM | #8 |
thru floor to chassis
11-10-2012, 12:08 PM | #9 |
start throwing tubes at it , but i still have a bunch more rust repair to go.
the back floor that holds tailgate, and back of truck together... for the most part GONE! i couldn't find any replacement panels,, so ill Fabricate my own. so i start by bending up and forming new parts |
11-10-2012, 12:18 PM | #10 |
bend up flanges, tack them in. make patterns
11-10-2012, 12:30 PM | #11 |
more parts, the "end caps" for C-pillar to floor, the floor stuff.
here i start on the top plates that hold the wood to the rear floor. made a dimpling die so the bolts will fit flush with floor. |
11-10-2012, 12:34 PM | #12 |
more stufff
11-10-2012, 07:54 PM | #13 |
Looks like you're going to do it right. How long have you been working on it??
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
11-10-2012, 09:20 PM | #14 |
11-10-2012, 09:48 PM | #15 |
since this frame was originally a side mount fuel tanks and spare tire under the bed,truck ... i cut out the cross member that went between rear spring shackles,built a crossmember that goes over the top and bottom of the fuel tank.. and built a 50 gallon aluminum tank
11-11-2012, 12:40 AM | #16 |
Excellent fab work!!
11-11-2012, 01:05 AM | #17 |
60-66 Nut
Very nice work
I like your dimpling die for the bolt recesses at the rear sill. Did you make that?
11-11-2012, 01:15 AM | #18 |
1 thing at a time is progress.
Dude, you've got it going on. Very nice work.
Alan
Philippians 2:14-16 |
11-11-2012, 08:33 AM | #19 |
1961 crewcab
I like it. Is there any suspension lift? and what size wheels and tires are those?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
11-12-2012, 12:30 AM | #20 |
Well i made dimpling dies a few years back ,the typicle round hole flare (1st picture) BUT I found i can get a little creative with mismatching top and bottom die sizes to get a few different results... this style one of them (2nd pic)
11-12-2012, 01:02 AM | #21 | |
i've been a fan of your stuff! no suspension lift to speak of , and the front springs are shot! I'm going to replace them....so the front should come up a bit. wheels -stock and tires are 35" x 12.50" x 16.5" , simply rollers for now, i have some 17"aluminum wheels... but I like the look now, and we know 16.5" are out! soooo...maybe some 17 steelies? Last edited by Franks Fab Shop; 11-12-2012 at 01:21 AM. |
11-12-2012, 01:19 AM | #22 |
I got to some plumbing,.. rear brake line, and fuel line, with 1st inline filter.
i convert to jic style -an fittings anytime i can! |
11-12-2012, 09:46 AM | #23 |
1961 crewcab
thanks, I like the look of those 35's.. I have been wanting mags for mine, but am also on the fence... the road de-icer here is h-LL on aluminum , so I might be better off with a set of steel wheels
11-12-2012, 11:19 AM | #24 |
Just here to tinker
Wow man. Incredible work! I'm totally jealous of your fab skills. That thing is going to be awesome!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
09-12-2014, 02:10 PM | #25 |
wonder what happened with this one?
ron |
