Old 11-10-2012, 09:12 AM   #1
richards72chevy
richards72chevy's Avatar
Can i use the 1 inch rotors on a 66?
The rotors on my 83 are only 1 inch thick.Will they work on my 66?I plan on leaving my cross member in there and swapping the a arms and spindle to my 66.
richards72chevy is offline   Reply With Quote
Old 11-10-2012, 10:32 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Can i use the 1 inch rotors on a 66?
Yes,... kinda.
You will need to use everything from the a-arms out.
(I assume your 66 is a half ton truck)
Since you are converting to 73-87 parts you need to use all the steering linkage to make things easy.
Those 1" rotors require you to use other 1" specific parts, like the calipers, bearings, and spindles.
So if you go to the parts store (or order drop spindles) you have to tell them you are using 1" rotors.
It makes a difference.
Keith
Convert to disc brakes.
Old 11-11-2012, 08:33 AM   #3
richards72chevy
Cool.Thank you.
