11-10-2012, 09:52 AM | #1 |
Blower motor
On my 87' the fan does not blow on HIGH. Blows on low, and mediums, but stops when switched to HIGH
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
11-11-2012, 08:40 AM | #2 |
Re: Blower motor
NOBODY ?????
11-11-2012, 11:24 AM | #3 |
Re: Blower motor
I had this same problem, turned out to be the black ground wire under the hood from the blower motor to the firewall.
11-11-2012, 12:30 PM | #4 |
BAD BOW-Silverado XST
Re: Blower motor
Low speeds go through the resistor. It's fine.
High speed goes through the relay. Replace it. I replaced mine about a month ago. $7 If the fuse blows after installing it, you'll have to open the relay. Later models have a resistor built in. I had to cut the resistor out so it would not blow fuses. It's November and I'm still driving around with the A/C at full blast!! |
11-11-2012, 12:33 PM | #5 | |
Re: Blower motor
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
11-11-2012, 11:56 PM | #6 |
Re: Blower motor
Right, and I'm a bit farther south than y'all
11-12-2012, 04:30 AM | #7 | |
Re: Blower motor
Also my blower motor doesn't move a whole lot of air even on max. I'm going to do that mod where you replace the blower motor with one out of a 94 pickup. They move a lot more air supposedly. |
11-12-2012, 07:23 AM | #8 |
Re: Blower motor
Mine is also does not blow much out of the vents but I think mine has something to do with that flap. I can feel the air out of the floor vets even then the selector is on MAX AC
11-12-2012, 08:30 AM | #9 |
Re: Blower motor
The A/C relay is behind the accumulator. In this pic, it's right above the low pressure switch. http://good-times.webshots.com/photo...54440533aYRkDg
It's painted black. The new one will be shiny "aluminum". Check the wiring. Since full voltage goes through it on max air, wires have a tendancy to burn up. Corrosion is also a problem. Next a fan cuts off, wiggle the wires at the relay. If it comes on and off, the wiring is bad. A stock fan, with all the vents properly open by vaccuum, will blow a lot of air in the cab. I can hear air going to the vents in my truck. |
11-12-2012, 08:19 PM | #10 | |
Re: Blower motor
I have seen the switch be the problem with this too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
