Any suggestions for armrests in a TF?
I would like to put some armrests in my truck and I'm wondering if anyone has found any junk yard armrests that fit up to the original mounting screw positions. I can buy new ones for $70 plus shipping but if there's something that fits that I can find at Pull-A-Part it would be a lot cheaper. The doors have captive nuts for arm rests built in and I want to use those rather than make something to fit.
Re: Any suggestions for armrests in a TF?
i think i got carried away
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
That may be easier said than done these days. after the mid 70's most manufactures started molding the arm rests into the door panel rather than have it bolt on the door panel.
Outside of some somewhat expensive aftermarket arm rests I doubt if you will find any that are a direct bolt on using the original captive nuts. I saved a pair for years that had a fairly long arm rest with a hand grip on the front but can't remember what I took them out of. Back in the 80's I scrapped a lot of cars out when people gave them to me and I drug them into the high school auto shop I taught in and took pieces off them to make training aids out of. I'm not even sure I have those in the shed anymore as that was close to 30 years ago and a lot of the stuff I stashed away then has self destructed. |
Isuzu troopers have old style arm rests. I got a pair of back door ones for ten bucks at local pick yard, look new.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
Here is a photo, upper right corner.
Toyota trucks and 4runners also have bolt on arm rests. Older (80s) Volvos, VW's, Benz's, and BMW's did as well. As to matching up with OE locations, well, some modification may be required.
If you are creative get some green Styrafoam stuff that is used for sticking fake flowers in flower arrangements. It hard density so it can be carved to your own designed. Next after you made two sets cover with fiberglass and sand it smooth you can use body filler too. Next use high strenth 3M upholstery adhesive and cover with material to match your interior. The styrafoam can be covered with plastic wrap making easier to remove or left in just remember to glass thin plywood or plastic against the side that mounts to the door panel.
http://www.joann.com/floracraft-2-7-...green/prd9873/
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#8 | |
When working with fiberglass dont forget mask, eye protection, long sleeve shirt and gloves (I use plenty of baby powder any where were my skin is exposed it helps and duct tape sleeves to shirt helps from gettin the glass particles in the skin)
#9 | |
The TF Trucks have threaded nutserts already behind the door panel. Get a screw that fits sharpen it to a point, install door panel back on lightly tap with a hammer to make an identation from sharpen screw. Drill out a little larger hole than in door panel than screw size come in from front of arm rest and screw in.
one thing i noticed when designing my door panels is that unless the arm rest is very wide (or your very wide) the arm rest will be worthless as an arm rest
my door panels are 1 inch wide and my arm rest hangs out 4 inches more for a total of 5 inches out from the door skin they are very comfortable there. ![]() @rudedude: i guess me fiberglassing in shorts, sandals and a t-shirt would make your skin crawl ![]() ![]() ![]() the only thing i wore consistently is disposable vinyl gloves
![]() Join Date: Mar 2007
I was lucky and got a great deal on some fiberglass ones off of EBay.
Normally they run about $125 - 150 for a pair. I think that I won the aucution for close to $40.00. They also have a pull handle which is nice. Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
#13 | |
It's a rainey day here in Ga and I couldn't get to the Pull-A-Part so I just ordered a set from Bow Tie Bits @ $35 each. The internet makes it entirely too easy to spend money, LOL. |
#14 |
I have a spare set of doors for a 92 Toyota pickup. The armrests look like they might be a good choice. So good, in fact, that I might tryand install them on my '57. I have some original rests that I saved from a 56 GMC but I haven't installed them because they seem too brittle.
#15 |
I had good luck with the stock ones from LMC and covered them to match the interior, either the AD or TF will fit the AD's
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#16 |
Your interior looks great. I didn't check LMC but I think the ones I bought from Bow Tie Bits are the same as the ones they sell. The catalog said they fit up to 66 models.
