Old 11-10-2012, 05:34 PM   #1
ubtripn
ubtripn's Avatar
Need some fast help
Just finished inner and outer bearings - how much resistance should i get when I spin it by grabbing a lug bolt? It turns but can anybody explain about how much?
When I turn mine it goes around once. (Wheel is off) Front wheel.
ubtripn is offline   Reply With Quote
Old 11-10-2012, 06:11 PM   #2
ubtripn
ubtripn's Avatar
Re: Need some fast help
Nevermind, I found it on the board searching. The castle nuts on my front bearings were completely loose when I opened it up!!!
Old 11-10-2012, 06:18 PM   #3
NoNeck
NoNeck's Avatar
I'm guessing you are talking about the bearings for the front. You should pre-load the bearings by getting the castle nut seated good and tight... in shade tree terms, a good grunt. Then, back the nut off to the nearest hole in the spindle that the cotter pin will slide through. You should be set.
I don't think you can really go by resistance because of variances in temperature, axle grease, new or old races, etc. Plus, pre-loading the bearings is important to lessen premature wear. Others may disagree.
Good luck.
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 11-10-2012, 06:28 PM   #4
ubtripn
ubtripn's Avatar
Thank yo VERY much. I torqued to 40 then backed off to the cotter pin hole, I could here it set. The wheel is good and steady now but holy crud was removing the races a pain!!!
Old 01-22-2013, 02:18 PM   #5
quentin hill
quentin hill's Avatar
Originally Posted by ubtripn
Did you ever find a resolution? Thanks for any help/info that you can provide.
I did, it was the front left brake pad. It was rocking back and forth in the calliper. So I put some new brake pads on it and no more noise.
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR"
quentin hill is offline   Reply With Quote
