Old 11-10-2012, 06:07 PM   #1
5150
C10 Club Tennessee
5150's Avatar
Gas Tank question...
Hey guys,
I'm running an 87 G20 Van fuel tank and I've switched out the pump to a high pressure one to withstand the 5.3. There are three lines coming out of the top of the tank. I only need a return line and a main line. Which one is which?
Also there are three wires coming out of the top also. One is the ground, what about the other two?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 11-10-2012, 07:23 PM   #2
Daaaanz67
Re: Gas Tank question...
If it has in tank pump then power for pump other one sending unit
Daaaanz67 is offline   Reply With Quote
Old 11-10-2012, 07:30 PM   #3
clinebarger
Black.....Ground.
Pink.......Fuel gauge.
Grey......Fuel pump power.
Remove the sender it will be obvious which line is which.
But will try from memory....
Left to right.....Vent, Pressure, Return.
clinebarger is offline   Reply With Quote
