Old 06-02-2003, 02:34 PM   #1
fastbagged68
fastbagged68's Avatar
Air bag kit
4 -bags choice between 2500 and 2600 firestones
40 feet 1/2 line
2- 3/8" - 7/16 orffice Parker dump Valves
2- 3/8" - 5/8 orffice Parker lift valves
1- FB fitting pack
1 thomas C315 175 psi Compressor
1- 5 gallon tank
1- steel braided Compressor line
1- 150 psi switch or 170psi your choice
2- switches
1 nut bolt pack
1 relay fuse pack
$1200 shipped
add $48 dollars for extra tank 3 gallon plus fittings
add $95 for 220 psi thomas compressor
add $200 for FBSS upgrade
Guage add on $50
Kit will be shipped upon payment
fastbagged68 is offline   Reply With Quote
Old 06-02-2003, 02:35 PM   #2
fastbagged68
8 piece c-notch add $80
Old 06-02-2003, 03:35 PM   #3
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
How much for a 2 way setup with 3/8 valves for my 72' without the bags(I have firestone 2500's and 2600's) I also have a airtank that I can use.
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 06-02-2003, 03:43 PM   #4
Frank_Zeller
Frank_Zeller's Avatar
Do you have any pics of the 8 piece C notch?
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 06-02-2003, 03:51 PM   #5
fastbagged68
its your typical 8 piece notch-
Old 06-02-2003, 07:32 PM   #6
fastbagged68
TTT- come on guys. Buy Air.
Old 06-02-2003, 10:30 PM   #7
PrimeredThunder
Back from the Dead
Price is kinda steep for me right now...I'm going to talk to a few friends and see what they can do. I'll let you know if I need anything though.
Thanks,
Kenny
Salem, Oregon
Old 06-03-2003, 03:50 PM   #8
fastbagged68
TTT- I need to sell these 2 kits.
Old 06-03-2003, 06:20 PM   #9
68_c10_on20s
68_c10_on20s's Avatar
kit
does the c-notch have to be cut into the bed?and will the bags fit in factory spring pockets?i mean front and rear coil spring set up as well,i also have have drop spindles on my truck will there be any clearance prob in the fenderwells?and can the tanks be filled with nitrogen for the faster drop?and will this kit lay frame the most important question of all....thx...Steve
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 06-03-2003, 06:23 PM   #10
68_c10_on20s
kit
does the c-notch have to be cut into the bed?and will the bags fir in factory spring pockets?i mean front and rear coil spring set up as well
Old 06-03-2003, 06:36 PM   #11
fastbagged68
This whole kit will fit in stock locations- you just drill holes in the frame for the rear bags,and the front make a plate for the top of the crossmember. The c-notch you can get to stay under the bed but if you really want to lay low you need to cut the bed. Laying frame or crossmember ? Crossmember you should be able to do withsome modifactions but most likely not with inner fender wells and 20's. To lay the over all frame you need to do some cutting. I will be doing a build up soon on that. You can run nitrogen through the system but you might want to upgrade to my 8 1/2" valve system. On 160psi its is very fast- very fast.
Any other questions justask.
Old 06-05-2003, 02:19 PM   #12
fastbagged68
TTT
