![]() Join Date: Oct 2012
Factory tool box??
Hey guys- I just purchased a nice rustfree 8 foot box for my 71. The right box side has what appears to be a factory toolbox built in to the lower front. the sheetmetal is actually stamped with a recessed lip that has a fiberglass box that extends in and is attached to the bed floor with brackets on the top of the rear of the toolbox. the door on the outside fits flush and has a piece of lower woodgrain trim acroos it. there is also a door lock cylinder on this door. I've never seen one of these. Are these common? I almost passed up this box because of the toolbox. I dont really like it but I do have a perfect rust free box side I can change this one out with. I just wondered if any of you have these in your beds or is this somewhat uncommon or rare? Just curious.
Re: Factory tool box??
They are fairly rare and worth quite a bit if they are rust free. I would just keep it for now. You will be thankful down the road when it grows on you and you realize how hard to it is find them.
Posted via Mobile Device |
The box side is perfect but the toolbox door is rusted out. the fiberglass box is in good shape though. If I do change the bed side, I will be drilling all the spot welds and carefully removing this bed side so it could be saved and reused on another truck.
I haven't gone to pick up this bed yet but when I do I will post some pics of the bedside and toolbox. Thanks for the welcome. Seems like a great group on here.
Its not a light yellow box is it?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
No. It's green and white
![]() Join Date: Oct 2009
Keep it, it will grow on you. It's a nice option in these trucks, and like Brian said, if it's in good shape, it's definitely worth a good bit.
if you really don't want it, you can stick a patch panel in its place, I've even seen a screwed on cover in place of the door - which of course looked 100 times worse than a door. I have to admit - I wasn't a fan when I first saw them - but they kind of grew on me. I don't have one now, but if I did, I'd keep it for sure. Btw, welcome to the forum! Pics are mandatory now that we've given you our 4 cents. |
The '71 Cheyenne has one- the lid's a little nappy, but it holds my smaller tool boxes (electrical bits, 1/4 drive set, hand cleaner, shop rags, etc.). Had to adjust the latch so it wouldn't rattle. It's a handy item, keeps a lot of clutter out of the cab.
I was gassing up (like usual- the 402 drinks deep) and I look over at a Ford pick-up, '70's vintage, with a bedside tool box also- with a chromed lid! I could only shake my head in wonderment. Posted via Mobile Device |
What is a straight rust free tool box bed worth and is there a separate key to unlock the box or is it keyed with the truck?
The 'trunk' key operates the lock. No idea what a pristine lid would be worth. It's pretty simple, probably easy to refurbish.
I mean the whole bed
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. |
#13 |
I'm pretty sure I'm going to swap out the toolbox bedside from my bed. I will be drilling all the spot welds and carefully removing outer bedside so it will be able to be reused if anyone might be interested. Toolbox itself is in good shape. The door is a little crusty. bed side is perfect. I don't know what this might be worth so I would be open to some advice or suggestions/offers. It will probably be at least a couple weeks before I get the bed home and remove the bed side.
#14 |
Pretty sure it would be worth more and salable to more people as a full side vs a skin. A skin is real hard to ship. But if you are willing to do all that work maybe splitting the panel at the trim line and wheelhouse might be easier all the away around.
#15 |
I agree with you but my trucks original bed was junk but the right outer skin was perfect. So I drilled and split it. So, I don't have a complete side to use. My father and I ran a body shop for 25 years and I did a lot of panels this way. I don't think it would be too bad to ship a skin. No different than a quarter panel for a car. IMHO.
#16 |
Well that is a very good reason. Really though, you don't like the tool box?
Making that side fit will be easy for you but I suspect that a lot of people are going to be leary of doing that much work. Really like yor advice sometime on an idea I'm kicking around for a 9 or 10' wood floor bed.
#17 |
It took a year and a half to find the bedside. I bought and sold a truck just for the door. It cost an arm and a leg. Finally the bedside toolbox is restored!
