Tot Roddin'
Aluminum Tank - Drain Required?
Curious what everyone's thoughts are on needing a drain on an aluminum air tank.
Overkill or justified?
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Never Ending Projects
Re: Aluminum Tank - Drain Required?
My thoughts are, you will still build up water in the tank, it just won't rust. The water will still go through the rest of the system, which could cause you problems, so you would want to drain it.
I would definitely put a drain in. YMMV
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
I'm with chevy mike i"d have a drain on any air tank no matter what its made out of.
been running airride since early 90s, never had any type of drain system. i do live in a desert, so my air might be drier then yours, but water going through your airvalves wont hurt them ifyou have high quality valves. -just take into account im in phx.
I'm not too far from him and we have some nasty humidity in the summer.
Tot Roddin'
Figured it would be the way to go, just like hearing everyone's experiences.
Man of Mini-Talents
It's interesting Ride Tech doesn't offer traps and stuff. A drain couldn't hurt though.
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
I would run a drain, as no matter what, the compressor will build condensation due to it compressing air. You won't want it going through your system, and even if your valves can handle it, I would not suggest letting water go into your bags. Most tanks will have some sort of drain port though.
Travis |
#9 | |
Posted via Mobile Device |
Man of Mini-Talents
Why not install a trap before the air even enters the tank?
No doubt, you have to do something if you run steel tanks/parts or you'll have rust flakes in your valves.
Even if you install a trap before the tank, you still need a drain. Condensation will build when the hot air that was pumped in from the compressor forms in the tank.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
The 'moisture' forms when the hot air cools. Traps immediately off the comp & just before the tank are useless. There would need to be a long enough lead prior to the trap that allows effective cooling of the hotter compressed air to reach atmospheric temps.
Although not an absolute requirement, any sort of drain (elect. valve or simple petcock) would be a benefit.
#13 |
Tot Roddin'
Wondered about the water trap as well, but understand the cooling that needs to occur in order for the trap to function as expected.
Would you need a water trap if running a tank w/ a drain? Right off the tank?
#14 |
No, a drain on the tank would be sufficient. I have never run a water trap on any of my air systems.
#15 |
how often are you draining? I open up and drain my garage compressor after every use. i cant imagine doing that on a daily driven truck is practical.
-- 1968 fleetside - nolimit wide ride front and rear + ridetech |
#16 |
You won't need to drain every time you drive the truck. Just every so often when you remember to do so.
#17 |
Water is essentially incompressible. So what ever water builds up in your tanks will reduce the volume of air that your system will hold in the tanks.
Unless you have another way of getting it out of the tanks, you need to run a drain in addition to a trap. I use a 1/8" NPT threaded schrader valve with a 1/4"NPT-1/8" NPT bushing, I got both at NAPA. Another added benefit is if your compresor goes out you can still air your system up through the schrader valves. |
#18 |
Obviously the schrader would need to point down. Here is a pic of mine during the install.
#19 |
dznucks that is the same drain I have on mine
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black ![]() Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
