Old 11-11-2012, 10:56 AM   #1
87squarebody
87squarebody's Avatar
drive line angle
Does anyone know what is the drive shaft angle supposed to be on a 87 short bed silverado.Its lowered with a 5/6 bell tech drop a flip kit in rear.Also where do I set the angle finder to get mesurement.I have a vibration/shake and want to rule that out.
87squarebody is offline   Reply With Quote
Old 11-11-2012, 11:24 AM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: drive line angle
If it is a one piece shaft, the two yokes should be at the same angle.
Dunenutt is offline   Reply With Quote
Old 11-11-2012, 05:17 PM   #3
olllie
olllie's Avatar
http://www.4crawler.com/4x4/CheapTri...FixingProblems
lots of good info on this subject.
olllie is offline   Reply With Quote
Old 11-11-2012, 07:51 PM   #4
thesickc10
with a belltech flipkit they say use a 4 degree pinion shim
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 11-11-2012, 08:29 PM   #5
Keith Seymore
Keith Seymore's Avatar
Not a valid question, since it varies based on ride height, axle orientation, engine angle, etc.
This should answer most (if not all) your questions:
http://67-72chevytrucks.com/vboard/s...d.php?t=522180
Ollie's information/link is good, too - says the same thing a little differently.
Basically you want the u joint working angles to be between 1 and 3 degrees (under load), and such that the front joint cancels out (is equal and opposite) the rear joint.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-11-2012, 08:35 PM   #6
Keith Seymore
Can you describe the vibration/shake a bit more?
Does it increase with vehicle speed?
Does it increase and then get better, or just continually worse with vehicle speed?
Does it do it under drive, coast or steady state operation?
Does it do it in neutral (stopped) by running the engine up?
K
1979-1986
1986 - 2019
Old 11-12-2012, 07:21 AM   #7
87squarebody
Thanks for the information.I set the rear of the truck on jack stands and spun the wheels and it seems like I have a tire that has a wooble or maybe a flat spot or bent rim..Im going to dismount tire and make sure rim is not bent.The shake/vibration starts at about 50mph and gets worse from thier.I let out of the throttle and its still their untill I get under 50mph.
Old 11-12-2012, 09:14 AM   #8
Keith Seymore
That sounds like a tire.
Driveline usually gets worse to a point, and then better as you increase speed. That's because the mass of the driveline doesn't have enough energy to drive a vibration throughout the whole truck without the multiplication factor of the resonance.
Driveline is also always torque dependent so you should be able to make it worse and better by tipping in and out of the throttle.
Tires - they're just bad. All the time (lol) - until you get below a certain speed.
K
1979-1986
1986 - 2019
