Old 11-11-2012, 11:19 AM   #1
ubtripn
ubtripn's Avatar
Economical GPS Speedo - got omine for 40 bucks
My 700R4 install nullified the stock speedo and the box to fix it is more than 500 bucks so I bought a Road Angel on ebay. They sit on the dash and give you your speed plus have radar/laser detectors. They are from the UK. If you pay for the subscription (I didn't) they all talk to each other to warn you about police speed traps, bad roads, and other things but I just wanted a temporary, cheap speedometer fix. I hard wired it and it works great. (Also has a compass.)
Just a thought for those without a working speedo on a daily driver.
ubtripn is offline   Reply With Quote
Old 11-11-2012, 01:23 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: Economical GPS Speedo - got omine for 40 bucks
I assume this reads in MPH?
Sounds like a good fix, if so!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 11-11-2012, 01:40 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Does this read out in analog or digital?
LockDoc
Leon
Old 11-11-2012, 02:53 PM   #4
ubtripn
ubtripn's Avatar
It does both Kph or Mph. Digital readout with adjustments you can make, many.
Old 11-11-2012, 03:09 PM   #5
DJMAN
DJMAN's Avatar
Can you link an item number for ebay please.
DJMAN is offline   Reply With Quote
Old 11-11-2012, 03:15 PM   #6
ubtripn
ubtripn's Avatar
Yeah, give me a minute.
Old 11-11-2012, 03:18 PM   #7
ubtripn
ubtripn's Avatar
This is what it looks like below. They come up now and again on Ebay. They also have their own website where they sell them for much more but if you watch for one it shouldn't take long on ebay.
Old 11-11-2012, 03:24 PM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: Economical GPS Speedo - got omine for 40 bucks
Nice product for a temp fix.
The best solution is a Speedhut GPS.
www.speedhut.com
Very nice guages and they are life time warrinty.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-11-2012, 03:29 PM   #9
ubtripn
ubtripn's Avatar
Yes, that is the best solution but i am pretty happy with this until I can afford that. I hard wired it in, used a piece of double-stick tape and it is very visible to me.
Old 11-11-2012, 07:47 PM   #10
cleanfreak
cleanfreak's Avatar
Great idea , but if you put in a 7004r , can you not just get the pieces fron an early 700 to convert it to cable?. I have done this many times on 81-87 p/u's , putting in 88-91 700r4's , not that bad of a job at all. Just my 2 cents , I'll probably get change back.... - Bob
cleanfreak is offline   Reply With Quote
Old 11-11-2012, 08:08 PM   #11
ubtripn
ubtripn's Avatar
I did not know that was even possible. Thanks! What pieces would I need to go hunt for?
Old 11-11-2012, 08:35 PM   #12
70cst
70cst's Avatar
Hey ubtripn ...
Thanks for the info. Great idea
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-11-2012, 09:00 PM   #13
ubtripn
ubtripn's Avatar
You bet!
Old 11-11-2012, 09:21 PM   #14
BarryB
BarryB's Avatar
On the back of your transmission. there is a place for you to plug into the speed sensor. basically what you do is remove the electronic one and replace with a mechanical one. like from a 87 down. There is if I remember correctly one bolt holding a retainer ring. once that is loose lightly tap on it until it comes out. Just be careful doing so, these are easily broken.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 11-11-2012, 09:22 PM   #15
BarryB
BarryB's Avatar
it is good to have the GPS so you can tell how far off the speedo is, or not.
Two rules in life.
Old 11-11-2012, 09:27 PM   #16
ubtripn
ubtripn's Avatar
Awesome, thanks - I am going to do it!
Old 11-12-2012, 10:02 PM   #17
cleanfreak
cleanfreak's Avatar
You also have to change the gear on the output shaft. Pull the tailstock off , you will see the electric wheel. pull that , install the plastic gear from the early 700 , I've usually pirated the whole tailstock from the early one. Hope this helps - Bob
Old 11-12-2012, 10:07 PM   #18
ubtripn
ubtripn's Avatar
Great, I am going on the hunt, thx again!
