![]() Join Date: Feb 2011
72 Custom Camper rear end ratio?
402 big block, turbo 400, with leaf springs. SPID card does not identify, looking for gear ratio options. I suspect 3.54 but not quite sure.
Anyone?
Jeff Horsman 1972 C20 Highlander "C" 1966 Olds 442 L69 four speed 1971 Skylark (GS clone racecar) 494 stroker 1986 Buick T-Type |
Moderator
![]() Join Date: May 2007
Re: 72 Custom Camper rear end ratio?
If you have a Dana 60 it is probably 3.54
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Ledddzepp has it right. A '72 C/20 400/Auto would have the D60 3.54 ration. With leaf springs 4.11 was an option.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
My 402/TH400 Custom Camper w/Dana 60 is (was) also a 3.54, though I swapped it for 4.56 when I added the overdrive transmission. Can't swear that they all had that same ratio, but from the posts above it looks pretty common.
A wire brush will tell all, though.
![]() Join Date: Sep 2007
If it's still in place, on the inspection cover of the rear end, usually on one of the top bolts, there should be a small metal tag. This will have the ratio embossed on it. Like the other guys said, should be 3:54 ratio. This is common.
Located the tag...3.54 is what it says. Thanks guys!
Hey!! No problem!! Enjoy that truck, keep her on the road!!
Just FYI Mine was stamped on the housing rather than on a separate tag, so if you don't see the tag you can generally still find it I believe.
