help identifying sensors
I have a few broken sensors the first is in the intake manifold and I have a pic of it and then I broke the sensor for the coolant in the drivers side head
could you tell me if the sensors are the coolant temp sensor or the temp switch thanks |
Re: help identifying sensors
That photo shows the coolant sensor that the computer needs.
The driver side cylinder head should have a coolant sensor for the instrument panal in the area between the #1 and #3 spark plugs.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
#3 | |
Chevys Kick A$$
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
I just swapped that one out on my 89 last weekend. The PO had it glued together. I went with the Borg Warner replacement at O'Reilly, $18.00.
1968 Chevy C/10 LWB V8 ![]() 1983 K5 Blazer 1989 C1500 Stepside Reg. Cab V8 |
| Bookmarks |
