Need Advice Tunning My Truck In
71 GMC 250 Six with powerglide
Transmission would not shift into high gear. Pulled it out and took to transmission shop and had it rebuilt. In the mean time I also put an HEI unit in instead of points. The transmission shifts well now, and the engine runs fine, but here's my problem: When it's in Drive or Reverse and sitting still with the brakes applied it runs very rough, not a miss, but like its lugging or trying to pull, it's feels like it needs a stall converter (but it don't, its all stock). If I idle it up high enough to run smoother I can REALLY feel it pulling then, like I'm trying to brake torque it and then it's "screaming" in Park. I'm wondering about two things: 1.) I put Type "F" transmission fluid in it, hoping for a firmer shift. Do you think that this could be my problem? Maybe someone has experienced this before? Should I drain/suck it ALL out as best I can and put Dexron III back in? 2.) I did not install a new torque converter. Do you think that maybe the torque conveter could be bad? What does a bad torque converter in a power glide act like... never had a bad one. Maybe something else?? Any advice appreciated. Thx |
The Older Generation
Re: Need Advice Tunning My Truck In
Sounds like you may have a vacuum leak somewhere. LockDoc
+1, check the lines on the tranny when they put it back in.
Weev- Posted via Mobile Device
Weev- Life's tough...... It's even tougher when your stupid - John Wayne |
I am a Referee of life.
You put Ford type Tranny fluid in it.There is a difference.Dextron is for GM.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
type f fluid is fine in that trans will not hurt the trans nor will not cause your problem.
Like said check for vac leak also check your timing and vac advance
Fuzzy |
