Old 11-11-2012, 05:28 PM   #1
72BlckButy
Tot Roddin'
72BlckButy's Avatar
2" Wide Leaf Spring Blocks - Where to buy
I'm looking for a supplier for 2" WIDE Leaf Spring drop blocks. Worst case we can make a set, but wanted to see if anyone sells them.
Thanks in advance.
Nate
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-11-2012, 06:12 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: 2" Wide Leaf Spring Blocks - Where to buy
Found these...
http://www.butchscoolstuff.com/store...ct_detail&p=70
Any other cheaper alternatives?
Would 1/4 or thicker square tubing with a grade 8 bolt be strong enough?
-Nate
Old 11-12-2012, 06:30 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Anyone?
-Nate
Old 11-12-2012, 06:36 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I like these solid aluminum blocks.
http://www.jagsthatrun.com/Pages/Par...ng-Blocks.html
But they are 2.5" wide.
Get me some dimensions,... and I'll see if I can make some.
Keith
Convert to disc brakes.
Old 11-12-2012, 06:40 PM   #5
n2billet
Village Idiot....
n2billet's Avatar
You are limited because of the 2" wide spring.....the last set I bought I got from Butch's.
Might check over on the Hamb....lots of old cars ran 2" leaf springs.
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 11-12-2012, 06:44 PM   #6
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I had ran across the link to the jag website but lost it. (Go figure...)
I'll check out the hub and get some dimensions drawn up.
Thanks guys.
-Nate
Old 11-12-2012, 08:25 PM   #7
mixermike
mixermike's Avatar
I bought mine from Butch also , 2" wide blocks are hard to find
mixermike is offline   Reply With Quote
Old 11-14-2012, 10:10 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the info MIke... looks like I'll have to keep Butch in mind.
-Nate
Old 11-14-2012, 10:15 PM   #9
mud.man.rj
mud.man.rj's Avatar
I keep a pile of them for a little extra lift on projects, buy them cheap from the auto wrecker a lot of trucks come with them from factory so real cheap to buy.
mud.man.rj is offline   Reply With Quote
Old 11-14-2012, 10:30 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
What vehicles did these come on from the factory?
-Nate
Old 11-14-2012, 10:46 PM   #11
mud.man.rj
mud.man.rj's Avatar
A lot of trucks, small 2wd and 4x4's. Just ask at the junk yard and see if they save them. We have a bus of blocks, all sizes and u bolts at our wrecker's here.
Old 11-14-2012, 10:58 PM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Thanks for the info.
-Nate
Old 11-15-2012, 01:27 AM   #13
mud.man.rj
mud.man.rj's Avatar
Your welcome, I used to work at a junk yard and still bought new parts only for years..then woke up one day and realised most things are reuseable if in good shape and way cheaper, sometimes need a bit of modifying but usually quite a selection. Good luck.
