![]() Join Date: Jul 2001
2 inch rear lift blocks / U bolts
I have a set of 2 inch rear lift blocks that I just removed off my 72 1/2 ton 4x4.The lift blocks are nice solid steel. The U bolts appear to be okay. The threads are fine and the nuts screw on very easy. The threaded part that was up past the U bolt retainers are a little corroded from the debris/dirt that was built up the U bolt retainer plates.
(2) 2 inch blocks (4) U bolts/washers/nuts Asking $45.00 shipped Thanks, Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
Re: 2 inch rear lift blocks / U bolts
What do you do about the front springs
[QUOTE=WETOWM;5697408]What do you do about the front springs[/QUOTE
I don't believe they make a block for the front, I could be wrong. . thanks, Ray
ttt
can anyone use these!
how much if I come and pick them up from you, I am in fairfax, va
#7 | |
thanks, Ray
Pm me ur address and i will pick them up sunday evening on my way back from ohio
Posted via Mobile Device |
