What engine oil and gear oil?
I recently got a '69 C10 from my grandfather. It's got a '71 307 and a TH-400. The rear axle is a '70 12 bolt. It appears to have a posi and about a 3.24 gear.
The truck runs pretty good. I want to go over everything before I run it much. What engine oil does this engine need? I'm guessing 10w-30 but I'm not sure. Also, what gear lube for the rear axle? Do I need some kind of additive for the posi? I'm pretty sure the trans just needs good old Dexron III.
1987 S-10 Blazzer Sold, 1986 GMC Jimmy Sold, 2002 Chevy 2500 HD 2wd, 6.0, auto. Sold, 2007 Chevy 3500 SRW 4wd D/A Sold, 2005 Chevy 3500 4wd CC, D/A, dually, 2001 Chevy 3500 4wd EC, 8.1/A dually, 1969 Chevy C10 short bed, 307 V8 |
![]() Join Date: Jan 2001
Re: What engine oil and gear oil?
I run 10w-30 year round in mine, and temps go from around 0 to 100+. For gear oil I use 75w-90. You need a friction modifier for posi. The trans will work fine with any Dexron; the later formulations are engineered to work in earlier applications.
One more question, what spark plugs should be in this engine? I could just get new replacements for the Champions that are in it but I have no idea if they are correct or not.
Might want to take a look at this thread, the manuals and a handbook are a great start.
http://67-72chevytrucks.com/vboard/s...d.php?t=544915
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
20' Daredevil (Ret)
![]() Join Date: May 2003
I also run 10W-30 (dino) all year and 75W-90 (synthetic) in the diffs. My Clymer shows AC R44 for a '71 307. As for brand, I've had good luck with AC Delco and Autolite, not so good with Champion.
20' Daredevil (Ret)
Ah shoot, I looked at the wrong model year 307, sorry. The correct AC# for a '71 307 is R45TS.
![]() Join Date: Sep 2005
R45TS gaped at .035 for points .045 for hei run the ac delcos and save your self alot of problems
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
