Old 11-11-2012, 08:03 PM   #1
ecgate
ecgate's Avatar
Cleaning up a Rear End????Sand Blasting It????
Just wondering if you guys use a sand blaster to clean your rear end before painting it. I am not sure if it causes problems with getting the media inside the rear end or if it is something i shouldnt worry about. As of now I have been using a wire wheel and it is hard to get into all of the tight spots. Any info would help. Thanks.
ecgate is offline   Reply With Quote
Old 11-11-2012, 08:17 PM   #2
chewychevy67
Re: Cleaning up a Rear End????Sand Blasting It????
i took mine to a engine shop and had them dip it in their tank. worked real nice and only cost me $60.00. they left it in the tank overnight and i had it back the next day.
chewychevy67 is offline   Reply With Quote
Old 11-11-2012, 08:24 PM   #3
HotRod C/10
HotRod C/10's Avatar
I wire wheeled mine........looks great!
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 11-11-2012, 08:26 PM   #4
ecgate
ecgate's Avatar
Chevy67 Would that require me to pull the axles and gears out of the rear axle or would I have it dipped in a tank as one unit?
Old 11-11-2012, 08:34 PM   #5
gearys 5600
gearys 5600's Avatar
I just had my 55 rear end blasted and powder coated. I used two layers of gorilla tape to tape all the openings real good before the blasting.
MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=423629
1969 custom/10 swb--SOLD
1968 swb 50th anniv.--SOLD
1967 camaro ss/rs..LS-6-speed, 16-year long project
1956 chevy nomad
1955 chevy 210 2-dr sedan
1978 el-camino ss 1-owner
gearys 5600 is offline   Reply With Quote
Old 11-11-2012, 08:46 PM   #6
midniteblues
midniteblues's Avatar
I did it in my camaro I didnt tape anything up but I did plug the vent and change the oil and gasket afterwards I havent had any problems in ten years with it knock on wood
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 11-11-2012, 08:49 PM   #7
69GWC
I wired wheeled mine as well worked great.
69GWC is offline   Reply With Quote
Old 11-11-2012, 09:58 PM   #8
truckster
truckster's Avatar
I blasted mine with aluminum oxide. Even though I was pretty careful taping it up, I got some inside and had to clean it out. I like the idea of dipping it in a hot tank. The only part you'd need to replace are the wheel and pinion seals and the cover gasket.
truckster is offline   Reply With Quote
Old 11-11-2012, 10:03 PM   #9
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I had mine sandblasted, by a friend who is also a car guy. He knows his stuff and how to take care of the parts. I used some Gorilla tape on the outside of the yoke. The diff cover was bolted into place. The vent was covered. After he blasted it, he painted it. The backing plates were left in place. I did pull the axles after we got it back, just to check it out and replace the axle seals. As an aside, my son got a bit energetic with the seal puller and trashed the cage on one of the bearings. So, a trip to NAPA to buy a new tool, a bearing and pair of seals....and life is good.
Member Nr. 2770
Old 11-11-2012, 11:13 PM   #10
chewychevy67
yes i did disassemble the whole thing. guess that may not be in everyones plan but it sure looks good.
Old 11-12-2012, 10:53 PM   #11
Chvy2NV
Chvy2NV is offline   Reply With Quote
Old 11-13-2012, 08:05 PM   #12
cleszkie
cleszkie's Avatar
I use Easy-Off oven cleaner. Spray it on, let sit, use a brush to work it into all the small areas, rinse off. Cuts right through all the oil and grease. Squeaky clean.
cleszkie is offline   Reply With Quote
Old 11-13-2012, 08:25 PM   #13
54belair
54belair's Avatar
What Ive done before and will this time as well is to soak the rearend in some type of solvent to soften the oil/soil caked on it, then scrape most of that off followed by sand blasting.
You can use about anything as a solvent: gasoline, or any spray on degreaser. I used some spray on bug and tar removed to degrease the underside of the cab. You can also soak it with dawn dish washing liquid and then pressure wash it (if you have a sprayer).
The sand blasting just does a good job of preparing the housing for primer/paint.
BTW: I like the easy off oven cleaner idea too!!!! (wonder if I could sneak it out of the house without getting caught?)
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 11-13-2012, 09:09 PM   #14
ecgate
ecgate's Avatar
Thanks for all the input guys. But after all the sleepless nights I have decided to stick with the ol wire wheel and sandpaper. I might try to use some easy off oven cleaner in the tight spots(if I do I will inform you how well it works).
