Old 11-11-2012, 08:22 PM   #1
blackdawg
Blackdawg
looking to buy a after market radiator looking
Hey guys time to get get rid of the leaky single core radiator in the the truck.In my build i have a chevy 350 engine and turbo 400 transmission.and have installed a trans cooler that i will also update.I have been checking around the usa i live in canada.the prices are much better in the usa.I want a three core aluminum rad that will just install like the stock unit.i found a couple online but the dimensions seem to be off.If somebody could lead me to a good radiator company or autoparts store that is priced right i would appreciate.thanks inadvance.
LIFE NEEDS NO RED LIGHTS !!
1966 chevy stepside. Aka Bella.
1998 chevy s-10 4x4 daily driver.
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=467164
blackdawg is offline   Reply With Quote
Old 11-11-2012, 08:55 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: looking to buy a after market radiator looking
Check this company out on ebay.. THis is the one I was looking at. They build custom ones too they may not be listed.
Here is their office contact info. Tyler - office (714) 225-4445
Several people here have bought one from here and I plan to whenever mine goes. They are in California.
http://www.ebay.com/itm/251104791967...84.m1438.l2649
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-11-2012, 09:35 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Champion radiator
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-12-2012, 01:32 AM   #4
luvbowties
luvbowties's Avatar
Exclamation Re: looking to buy a after market radiator looking
Study the 3-2-1 core cooling specs and esp. size tubes in each of those radiators. Some 2-core ones have bigger flow tubes than some 3-core ones and cool better than those 3-core ones. 2-core ones may be cheaper also.
Just a heads-up.
luvbowties is offline   Reply With Quote
Old 11-12-2012, 05:05 PM   #5
beefshreadder116
beefshreadder116's Avatar
i bought a champion economy series $140 shipped. works great never had a heat issue. there are 2 issues i found when istalling. 1st the upper tank is just slightly thicker than stock; i just took the rubbers to my wire wheel and shaved the down 1/16". 2nd the pet cock sits right over the inside of the frame rail; i took a large creseant wrench to the open side of the frame where the pet cock would sit and slightly bent it down. i didnt find out the pet cock issue until i had already filled the rad with coolant, just trying to give you a heads up.
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
Old 11-12-2012, 08:53 PM   #6
63burban
Chevy addict
I used a $129 rad from Speedway Motors, made a schroud and the truck runs at 180 all the time.
63burban is offline   Reply With Quote
