Old 11-11-2012, 11:03 PM   #1
BIGBLU 72
BIGBLU 72's Avatar
Hydroboost Brake Lines
Im going to switch to Hydroboost over winter to hopefully fix my terrible breaking problems. My question is should I change to a larger diameter brake line, avoid compression fittings, or anything else like that?
What do I do about the actual brake rod for this conversion?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 11-12-2012, 01:07 AM   #2
yossarian19
Re: Hydroboost Brake Lines
You don't need larger diameter lines unless you are changing the diameter of the hydraulic components. There is no increase in brake fluid flow, only in pressure.
You want to absolutely minimize the number of fittings and maximize their quality. Hydraulic brake boosters will usually double (or more?) line pressure. If a connection is marginal with vacuum boost, hydraulic may blow it out.
Compression fittings are considered by the ASE to be sub standard and to be avoided in *any* brake system. Use double-flared brake fittings. You may find somebody on the internet or local to you who disagrees with me, and that's fine, but I'd go with the ASE on this one.
yossarian19 is offline   Reply With Quote
