Old member
Has anyone measured a late model 6 lug rear end to see if they would fit a 71 truck frame? Better yet doews anyone have pictures of one installed?
Been wondering how much trouble it would be to put one under a 71 and have the axles done for the 5 on 5 bolt pattern to gain the disc brakes.There is a local junkyard that has several of these rear ends. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Late model rear end?
I recently started to look into this same thing as a friend of mine was going to swap out the rear end on his '06 Tahoe and he asked if I was interested in it. I was interested for the same reasons...disc brakes, 3.73 posi... I figured I could swap the axles to keep my 5 x 5 bolt pattern. Before I got too far into it, he changed his mind.
But my initial findings were that it would probably be a few inches wider. Plus the brackets would all have to be cut off and new ones welded on to match the truck arms. I'm not to far from you, Andy, so if you find out more and it's not unreasonable, maybe we can work a deal for 2! - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
Old member
Well next time I go to the junkyard I'll get some measurements and look at it some more.
I do know that the 88 up rears are wider, not sure about the newer ones with disk brakes. I've seen were guys with 73 up trucks have put them in to match the front axle widths. Hope this helps some, I know glock put one in his Fred build and he mite have some measurements.
Dan G ![]() Lift it, fat chicks cant jump! 83 Chevy shortbed 4x4: 6.0 ls powered 97 Chevy 3/4 ton ex cab 454: work horse 00 Chevy camaro: daily driver 83 Chevy 3/4 ton: dads old rig |
Old member
Well depending on how much wider they are it may help with the tires rubbing I had without the spacer installed. It can come out further in the wheel well and be fine. I guess it's time to make a trip to the junkyard.
I am a Referee of life.
Don't forget to check the Trailblazer also.They might be the right width.The nice thing about the later axles over installing disc on a stock one would be the better selection of ratios,and thease of finding a posi.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
