Old 11-12-2012, 10:48 AM   #1
Bustd Knuckles
Winndshield washer pump
Just re assembling my '72 C/10 after inside out paint and got to the point of re installing my wiper/washer assembly. I rebuilt the washer pump and while I had it on the bench I hooked it up to 12volts and all I got from the washer pump was a click. The cam moved but the plunger didn't . Is this as it should be ? I just used the 2 terminals leading to the pump with the 12 volt jump pack. Want to get this operational before putting the rest of the dash together . Any help would be appreciated.
Bustd Knuckles is offline   Reply With Quote
Old 11-12-2012, 11:19 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Winndshield washer pump
What you're probably hearing is the solenoid releasing the piston to engage the cam on the motor. The wiper motor turning moves the washer piston up and down with a cam and resets it until you push the knob in again.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 11-12-2012, 11:26 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
This thread might help you.
http://67-72chevytrucks.com/vboard/s...d.php?t=413551
Like 68gmsee said the wiper has to be turning for it to work...
LockDoc
Leon
Old 11-12-2012, 12:03 PM   #4
Bustd Knuckles
Thanks guys,I'm on it.
Old 11-12-2012, 12:17 PM   #5
68gmsee
Active Member
68gmsee's Avatar
If you rebuilt the old pump, you will more than likely find out it won't work properly. New imported rubber parts are cr@p. I've tried twice and finally gave up and installed a small electric pump motor under the dush. It's activated when I push the knob in. Only thing is that in order to keep it running you have to keep the wiper knob pushed in. It's not that big a problem here since we haven't gotten much rain lately.
06 Trailblazer
