11-12-2012, 06:47 PM | #1 |
"U.9,000" on my doors. Is this really the capacity?
My '69 Custom 20 LWB 3/4 ton has these stickers on each door. They look like they are probably as old as the truck. I'm assuming this is the weight the truck was rated to carry, but on the metal door plate, it says 7,500. So, which is it? Did the truck get some sort of extra add on to allow it to carry more weight, or is this sticker the 1960's equivalent of someone buying emblems from a higher end Mercedes off eBay, to put on a lower end Mercedes to make the neighbors think they've got something they don't?
Maybe I'm missing how the weight is calculated, so please let me know. Thanks Posted via Mobile Device |
11-12-2012, 07:08 PM | #2 |
Re: "U.9,000" on my doors. Is this really the capacity?
Utah's registration laws that were in effect when your truck was registered required all 1/2 tons to post U6000 and 3/4 tons to post U9000 somewhere on the sides. It didn't actually reflect the manufacturer's gross weight rating. The requirement is long gone and you can get rid of it. It looks like maybe they're vinyl letters you could remove with a heat gun.
11-12-2012, 07:14 PM | #3 | |
11-12-2012, 07:34 PM | #4 |
We kind of touched on this before when you first got the truck. The max. capacity of your truck is 7500 lbs as are all C/20s IF PROPERLY EQUIPPED! The number on your fender is simply stating that your truck has a gross weight under 9000lbs for licensing purposes. Some regions had this requirement and it was often a decal or painted by a sign painter.
The earlier trucks had the one rating on the plate. Later trucks had gross, front and rear capacities for "as built" and maximum capacity. Again IF PROPERLY EQUIPPED. The Owners Handbook in all cases will show the capacity requirements. These are broken down into the spring and tire options required to meet the various capacities. Some of these old tires are very hard to find in the heavier capacities. If you have changed to tire sizes and wheels that are not listed you need to make sure they are up to the task.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
11-12-2012, 07:38 PM | #5 | |
Tim to the rescue. Thanks again Posted via Mobile Device |
11-12-2012, 07:39 PM | #6 | |
11-12-2012, 07:59 PM | #7 |
Here is a chart from a '71 handbook.
If you do repaint the numbers, I have always liked them either below the front fender series emblem or on the front lowermost bedside.
11-12-2012, 11:13 PM | #8 |
It used to be that they sold some nice decals that were in kind of a script. Seems like every little store had them. The 'U' stickers went away around the same time when we no longer had inspection stickers on the lower left corner of our windshields. I'd say off hand sometime in the mid to late '80's. I used to have a '88 Ford pick-up that had always been in Utah and it never did have the 'U' sticker, but now that I'm thinking of it, my kid had a '86 and I'm pretty sure it had them.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
11-14-2012, 03:53 AM | #9 |
Finally found a picture I've been looking for.
11-14-2012, 10:54 AM | #10 | ||
"I ain't nobody, dork."
If memory serves me right... Some states even let you register the vehicle for farm work and you then letterd the words "FARM USE" or "FARM TRUCK" on a rig, and then it was excempt from licensing laws. Didn't even need a license plate. Could only be used on the farm or for short trips "in to town" for supplies.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
