Old 11-12-2012, 07:01 PM   #1
Rodent
Rodent's Avatar
Unplugged Computer Controlled Quadrajet on older truck
I had a good computer controlled quadrajet given to me, it came off some guys daily after he stuck a Holley on it. I seen it driving around daily, so I think it is good.
Since this is an electric choke model, is there anyway I can stick this on my beater '82 4x4 with the sensors and stuff unhooked, and run keyed 12 volt ignition to the choke plug?
Or is there someway to put this electric choke setup on my divorced choke carb?
It currently has a divorced choke quadrajet with all the linkage removed and it's pretty hard to start. This truck is a rolling rust ball that only gets driven about 12 miles a week so I'm not too concerned about how it looks or getting the best fuel mileage/performance. Or spending anymore money on it.
Rodent is offline   Reply With Quote
Old 11-12-2012, 07:52 PM   #2
C-10 simplex
Re: Unplugged Computer Controlled Quadrajet on older truck
i don't think the CCC carb will run right without the computer, because the computer controls the metering rods and to a certain extent, idle rpm.
i think you can switch to a electric choke from remote type. Why not try converting to manual choke?
C-10 simplex is offline   Reply With Quote
Old 11-12-2012, 08:35 PM   #3
Rodent
Rodent's Avatar
All the pieces of linkage are missing, the choke plate just flops around. Other than that its a good carb.
This carb has a plug on the top, and plug on the side near the throttle linkage. Is this computer controlled or a dual pump shot?
Old 11-13-2012, 01:23 AM   #4
Malo83
Cruzzzn' Vet
Malo83's Avatar
E4ME Quadrajet, does it look like this, as was stated earlier, it needs a computer to run
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 11-13-2012, 03:15 PM   #5
Pyrotechnic
Pyrotechnic's Avatar
The electronic solenoid pulses the primary metering rod up and down constantly, like a fuel injector does. This was GM's cheap and primitive way of making the carburetor perform more like expensive fuel injection. In a regular quadrajet, a vacuum control piston moves the rod up and down based on engine load.
If you are skilled in electronics, you could make a circuit with a vacuum sensor to mimic the operation of an original quadrajet. Nothing is impossible, but in the end it's probably just not worth the time or effort considering how cheap you can get a used Holley or Edelbrock.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 11-13-2012, 03:19 PM   #6
SSC's76
No No
SSC's76's Avatar
you may be able to convert the choke over just depends on you current carb body most will work some will not. if you try to run this ccc it will work but it will be rich as heck all the time
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-13-2012, 07:28 PM   #7
Rodent
Rodent's Avatar
I'm going to see if I can adapt the electric choke assembly and linkage onto the divorced choke setup. Looks like it'll work, so we'll see.
Old 11-13-2012, 08:13 PM   #8
INSIDIOUS '86
INSIDIOUS '86's Avatar
My old 305 had this. Didn't seem to Change anything on my 305
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 11-13-2012, 10:12 PM   #9
Pyrotechnic
I believe the mixture solenoid stays in the rich position if there is no signal to it. If so, I bet you won't even need the choke. It's gonna be like a Holley with a blown power valve. Just safety wire the choke flap open.
Old 11-13-2012, 10:24 PM   #10
C-10 simplex
The computer carb won't work unless significantly modified---all the computer stuff taken out and replaced with non-computer components.
If the truck is only driven 12 miles per week, suggest physically closing the choke by hand when cold and opening it up after 30 seconds or so.
