11-12-2012, 10:14 PM | #1 |
86 C10 Lowering Issue
Anyone ever have a conflict between the lower control arm and 15" wheel scrubbing each other right at the lip on the arm next to the ball joint. I'm using belltech spindles and springs. Any thoughts.
Thanks Posted via Mobile Device Last edited by dealrcn; 11-12-2012 at 10:20 PM. |
11-12-2012, 10:23 PM | #2 |
Re: 86 C10 Lowering Issue
I ran into the same issue on my 65 with an 85 crossmember, I have 2 1/2' drop spindles and ended up buying a set of wheel spacers that I believe are 8mm thick. I installed longer Lug Studs in the rotors to compensate for the spacers.
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
