11-13-2012, 12:37 AM | #1 |
How much miles did ur lsx motors have??
So I heard and read about lsx motors running great up to 300k miles. I was wondering how much miles did ur motors have when u bought em. I want to get one under 150k miles.
Posted via Mobile Device |
11-13-2012, 02:07 AM | #2 |
Re: How much miles did ur lsx motors have??
whatver you get dingle berry hone the cylinders, put in new rings, bearings and have a zero mileage short block. your most likely going to do a cam swap 9you'd be nuts if you didnt) wiht new valve springs, so while you got them heads off spend the 500 bucks and have them reconditioned..
now you have a zero mileage motor on a budget rebuild. |
11-13-2012, 06:10 PM | #3 |
unlike the other dude, my budget build is a straight up budget build!!!! I dont have time or money to tear it all down and spend a bunch more money on all that stuff, thats why I bought my 5.3 to begin with, because their a 100K tune up engine. I got mine with 89K on it and was very pleased because I just wanted one with less than 100K.
11-13-2012, 07:14 PM | #4 |
Moderator
Replace the timing chain, check your valve train (bent pushrods, wiped lifters, etc.) and rock and roll. Oil pump is cheap insurance too. No need to get too carried away, if you're going with mostly stock.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
11-13-2012, 09:16 PM | #5 |
Fabricate till you "puke"
2nd that....my 5.3 has 137,000 on the clock. Good runner, but I plan to open the old gal up, for closer inspection. One other thing I might mention is valve springs....up grade to stock(stock cam ), or upgrade to cam specs, if replacing the camshaft. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-13-2012, 09:20 PM | #6 |
Yeah I don't want to go too crazy with the whole tear down and rebuild...I'm on a tight budget. Although checking the timing chain and valve train isn't a bad idea...but tearin it down to the bare block is too much with my little bit of cash.
11-13-2012, 09:22 PM | #7 |
meowMEOWmeowMEOW
bought it with about 60k on the clock. I didn't even change the timing chain or oil pump...just threw the swap pan on it, biga$$ cam, pushrods and springs and ran it. Put 10k miles on in less than 3months worth of total driving under interesting conditions, no problems, better mpg than my daily, fast.
seems a little ghetto fabulous in retrospect, but my lq4 has been nothing short of excellent. Now it just needs some rod bolts, a different cam and about 12psi.....ain't nothing wrong with 600+hp stock shortblock stock heads cars.
11-14-2012, 06:56 AM | #8 |
<2 miles. Mine came from a totalled new Suburban. No rebuild required!! Wouldn't say it was low budget though. But its gone all over the country after putting it in 96 S10 Blazer and then my 68 C20. Towing travel trailer too. No problems from it so far. If its just local use, I'd just check the pan and valve covers for cleanliness, change the fluids and filters and maybe the plug wires, plugs and drive it to find out what kind of condition its in. They aren't hard to repull from these trucks for a rebuild if absolutely required later.
11-14-2012, 09:31 AM | #9 |
1965 Chevy C10, 2005 4.8L/4l60
Mine had 7K on it.
My BIL had a 2002 Silverado 4x4 with 285K on his, he traded it in since the front suspension/drive axle needed rebuilt anyway. I dont think he ever had anything done to it but maintenance.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-14-2012, 09:49 AM | #10 |
My '96 5.7 had over 200k. I was prepared to rebuild it but thought I would leave it alone and see what happened. So far I've just done the intake manifold gasket, replaced two injectors and two O2 sensors. I have about 15k miles and doing just fine.
11-14-2012, 10:07 AM | #11 |
My dad's got a '99 Silverado with roughly 250k on it. No problems at all.
71 K20 64 GMC mud truck |
11-14-2012, 10:13 AM | #12 | |
Charlie Daniels w/ a Tq Wrench
My brother owned a 2500HD with a 280k LQ4 and it was still running strong with no smoke. Personally, the 5.3 I bought for my 67 had 70k mi on it, I'm just cleaning up the outside, painting the block, and sticking it in ready to go.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
11-14-2012, 01:56 PM | #13 |
Truck and auto performance nut
O miles. Installed a .650 dual spring/retainer/seal/keeper set and chromoly p-rod change on it with the over .600 lift cam I installed... and to remove VVT.
Still have those new, 0 mi. parts too that would work great to freshen up the top end of one of those hi mile motors....
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
11-14-2012, 02:26 PM | #14 |
Boosted Member
My turbo 5.3 was a 150k engine...ran great and still does.
My 6.0 in the boat was a 120k engine...ran great (for miles and miles at 5500 rpm...) and still does. My turbo 6.0 had 70k on it. ditto the above. I just do the usual stuff: LS2 timing chain, ported stock oil pump, drilled lifter trays, dual springs and hardened pushrods if doing a cam, head gaskets and studs if doing a turbo. Don't sweat it too much, these motors are bulletproof. No need for a teardown unless you KNOW something is wrong and needs to be fixed.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
11-14-2012, 10:23 PM | #15 |
I was a bit nervous when mine arrived because it was so dirty on the outside, but turned out to only be valve cover gaskets, and the inside of it was very impressive how clean everything was with no build up or anything that would imply it had many miles on it. Put new top end gaskets on it and o-rings, and gonna run it.
11-17-2012, 08:04 PM | #16 |
248,000 on my 01 5.3L ran strong
11-17-2012, 08:36 PM | #17 |
One of our work trucks is a 2000 1500 5.3 and it has about 312,000 and runs great . Oil changed with Wallmart cheapo oil.
11-18-2012, 11:25 AM | #18 |
my 04 lq4 supposedly had 120km on it when I bought it from a wrecked van...looked more like 180km..changed oil pan, doesnt burn a drop of oil, no ticks, beat on it all summer....awesome!
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
11-18-2012, 06:59 PM | #19 |
227,000 on 5.3. Looked good on inside but replaced the springs with Z06 springs, cam, & oil pump.
11-19-2012, 12:35 AM | #20 |
76k on my 5.3L in my 68 and running good.
I have 156k on the 5.3L in my '03 suburban and it runs just fine. I'm hoping the tranny continues to hold up as I'm to the point where they start wearing out, but I don't hot rod the 'burb. |
11-19-2012, 12:55 AM | #21 |
I emailed the guy a justchevytrucks.com and he said that I can get the lsx package(motor,trans and stand alone harness and ecu) for $1800. Only problem is shipping is really pricey(from Maine to South Dakota). This deal sounds so good but Im thinking about going with St James auto parts in Missouri since its closer and shipping would be cheaper.
11-20-2012, 11:18 PM | #22 |
Check out Remington auto salvage in Wisconsin. I contacted Chad, their Ebay department salesman, who dropped the listed price if I bought straight through him over the phone, instead of doing the buy it now stuff on the website, then I was able to have it shipped to work, which is a commercial address, which saved another $200 on shipping. In all, it cost only $300 to have it shipped from Wisconsin to Oregon, and they had it here in 6 days.
