Old 11-13-2012, 11:35 AM   #1
BREAKER ECV1849
Help how to measure new drive shaft
Just did a swap from a th350 to a sm465 need help on the correct way to measure a new drive shaft.
BREAKER ECV1849 is offline   Reply With Quote
Old 11-13-2012, 12:21 PM   #2
Redcap
Re: Help how to measure new drive shaft
Center of u-joint to center of u-joint.
Redcap is offline   Reply With Quote
Old 11-13-2012, 01:12 PM   #3
Keith Seymore
Keith Seymore's Avatar
If you are having a shaft made I'd recommend you contact the shop and ask them how they want you to do it.
I've showed up before with my own measurements and they made me go home and do it their way. (Shaft is still too short IMHO).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-13-2012, 01:29 PM   #4
Moostifer
a fool with no money
Moostifer's Avatar
www.markwilliams.com has some good info on driveshaft measuring and setting angles. print out the sheet, write down all the measurements, fax, email, or go to your local shop, and like Keith said, hope they dont send you home for another measurement.
Basicly stock 83 SWB with a few Bolt-ons
before, during and still during
http://photobucket.com/albums/y251/moostifer/truck/
http://photobucket.com/albums/y251/moostifer/motor/
Moostifer is offline   Reply With Quote
Old 11-13-2012, 08:56 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
My shop has me bottom the yoke into the transmission then pull it back out 3/4 of an inch. Then measure from center to center from there. This is all done with the truck at ride height.
Old 11-14-2012, 09:49 AM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
my shop was exact same way
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-14-2012, 11:37 AM   #7
BREAKER ECV1849
Sweet thanks for all the help got the drive share measured and dropping it off at the shop today.
