11-13-2012, 01:17 PM | #1 |
Oh,you can't buy that new
bent pushrods on initial run in?
Alright a few weeks ago i posted a question asking what would be the length of pushrod i needed for a 1990 block with earlier heads. the heads are #882 which are the better 'bad' heads from the late 70's. Very professionally done, all new valves & such. There should be no isssue here at all. this was NOT a roller motor so the stock 7.800 pushrods are the right ones? I ordered up a set of no-name hardened pushrods because these heads do have Z28 springs,guide plates and screw in studs now. Anyway i know what I'm doing when it comes to adjusting hydraulic lifters. i do one cyl at a time. done it my way 50 times before and never an issue. never have to re-adjust either. I had the intake off when I did them and verified my work. So anyway, I'm almost always there when something i built gets fired up. I wasn't there for the first 5 minutes. They said they had it at a high idle, like i told them to do, and that it ran fine, but yet they were installing a new carb when I got there because they said it blew back up thru the carb(eddy 600). I found the timing to be very retarded and when I fired it up it was 'ticking' exhaust back thru the carb. i knew that was valve adjustment type issue. when i pulled the left valve cover- ALL the exhaust pushrods were bent bad. The intakes were fine and the whole other side of engine is fine. They said when they shut it down it 'popped'. I measured these new pushrods and they are 7.800. My question is could the timing being that retarded cause these cheap (hardened) pushrods to bend. thanx, crossy
1990 350 TBI block 1978 350 #882 heads cam is hyd and only .460 lift
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone 73 Pinto, stock, w/CragarSS's-eww LOTS of Cummins trucks. |
11-13-2012, 01:44 PM | #2 |
Re: bent pushrods on initial run in?
Ive seen the pushrods bend in motors when it kicks back do to timing issues......but a hydralic cam is more forgiving than a solid lifter motor..set at zero lash than 1/4 of a turn
11-13-2012, 04:32 PM | #3 |
Just here to tinker
It's weird that only one bank bent. Did you check piston to valve clearances?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
11-13-2012, 05:31 PM | #4 |
Maybe.
I had a similar experience. New build, full roller (solid lifter). Break in went fine, drove the car around the block a couple times, but first hard acceleration - everything went all to heck. Limped it home and had bent nearly every pushrod (like 6 intakes and 7 exhausts). Bent them into an "S" shape. The amount of collapse just happened to be the same amount as the lift on the cam. Not to name names but these were Comp Cam pushrods. I hit them with a file and they sure seemed soft to me. I knew the Chief Engineer at Comp Cams at the time so I sent them back and we had a little conversation. He never admitted guilt but they did sent me a new set of pushrods - which worked fine. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-13-2012, 06:24 PM | #5 | |
I'm going to through some factory pushrods back in until i know it's not going to try that again. The hardening is only needed because of the guide plates . yeah, it bent em like an S. Also i doubt these Hyd lifters are very forgiving as the engine was holding 80 psi at idle. thanx, crossy
