Old 11-13-2012, 02:50 PM   #1
oldmann1967
Add a tach?
My '81 Scotts does not have a tach. I want to replace the LARGE fuel gauge with a large tach, then put a small fuel gauge in one of the blank spaces in the bezel. What do I need to do? Can I get a small fuel gauge and plug and play from the big fuel gauge? What do I need besides the harness for the tach? I see I can buy this stuff from LMC.
Thanks!!
oldmann1967 is offline   Reply With Quote
Old 11-13-2012, 05:04 PM   #2
77ChevySharkBite
77ChevySharkBite's Avatar
Re: Add a tach?
I would look into maybe going to autozone or something that a cheaper alternative in reference to a tach, um....from what I've been told if you get a new fuel gauge you'll have the get all new equipment such as the "bobber" that goes into the trucks tank, as far as wiring I dont see why you couldn't use the old wiring and it work.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 11-13-2012, 07:42 PM   #3
liftlawssuck
liftlawssuck's Avatar
Re: Add a tach?
You need to replace the printed circuit board on back of cluster and possibly the white plastic housing. Can't remember on that last one. Your best bet is to buy a whole instrument cluster that has a tach in it. Look on the parts boards here. They come up quite frequently. Not real cheap but available. I bought all my stuff right from GM. The only thing I didn't buy was the tach itself.
liftlawssuck is offline   Reply With Quote
Old 11-13-2012, 10:01 PM   #4
xole
xole's Avatar
Re: Add a tach?
This is pricey but does the trick.
http://www.gmsportssalvage.com/?q=node/1530
'86 Chevy K10 SWB Custom Deluxe 4x4
'94 Chevy Corvette
'07 Ford Mustang
'08 Lexus LS 460
xole is offline   Reply With Quote
Old 11-13-2012, 10:33 PM   #5
oldmann1967
Re: Add a tach?
Yesssss! Thanks!
Old 11-13-2012, 10:37 PM   #6
J Knight
J Knight's Avatar
Re: Add a tach?
I installed this one last year, works perfect.
Here is some install pics, start at post #54
http://67-72chevytrucks.com/vboard/s...el+gauge+combo
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 11-13-2012, 10:47 PM   #7
68Timber
I know the pieces fit
68Timber's Avatar
Re: Add a tach?
Love this option.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-13-2012, 11:09 PM   #8
Evil Trailblazer SS
Big Gulps Huh? Whelp...
Evil Trailblazer SS's Avatar
Re: Add a tach?
I searched for months and paid $200 for a donor tach cluster, plus had to buy the last brand new NOS '81 cluster case in GM's entire dealer network, a new printed circuit from Classic Industries, some gloss ultra white spray paint, 3-chip LEDs, and here is what I ended up with...
"The Ghost II" - 1987 V30 CC, 14-BFF (2nd Design Heavy Ribbed HD) SRW Conversion, 454/4L80E/205, 6" Springs, 35" Toyo MT's on 17" Classic II's, Full Audio System, Lot of Other Goodies!
Evil Trailblazer SS is offline   Reply With Quote
Old 11-13-2012, 11:50 PM   #9
Cramitthefrog
It's always something
Cramitthefrog's Avatar
Re: Add a tach?
If you have or can get the tach and small fuel gauge the only thing you need to get is a housing that has the clock in it which are fairly easy to find. You can reuse your printed circuit. This is very easy to do with just some junkyard parts.I could explain more and maybe track down some pics if you want to piece one together.
Cramitthefrog is offline   Reply With Quote
Old 11-14-2012, 12:04 AM   #10
Evil Trailblazer SS
Re: Add a tach?
^^^Exactly! As long as you don't have a dummy indicator dash, the printed circuit "should" work fine!
Old 11-14-2012, 01:39 AM   #11
wraprail
wraprail's Avatar
Re: Add a tach?
You can do it on the cheap with a clock cluster, small factory fuel guage and a tach from a 1970-81 camaro (very common in wrecking yards and they read to 7000 rpm)
Solder a wire on circut board from your fuel guage signal and attach to new fuel guage with ring termanal, add power and ground and mount where clock was. (Only one screw but its enough)
Tach just needs power and ground from circut board and run one wire to dist. for tach signal. I also used the speedo from camaro which just bolts in and reads 150mph.
Less than $50
. [IMG][/IMG]
wraprail is offline   Reply With Quote
Old 11-14-2012, 09:54 PM   #12
gmachinz
Re: Add a tach?
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
gmachinz is offline   Reply With Quote
Old 11-14-2012, 10:26 PM   #13
82ccshorty
82ccshorty's Avatar
Re: Add a tach?
are the diesel versions valuable?
1969 chevy camaro Z28 #matchin Factory 4wheel disc
1969 chevy cst10 big block overdrive 5/7 drop dog dishs
1997 gmc yukon 2 door 2 wheel drive project 4/5.5 22s
2004 gmc sierra dually 4/4 lowering daily driver
82ccshorty is offline   Reply With Quote
Old 11-14-2012, 10:38 PM   #14
gmachinz
Re: Add a tach?
Typically-no. The gas big series trucks had a 5K tach. Those would be the better route. They are good for tach cluster parts should you find a 5K tach from a big series truck.
Old 11-14-2012, 10:59 PM   #15
82ccshorty
82ccshorty's Avatar
Re: Add a tach?
I didnt know this truck I just bought has one that comes with it but it's a diesel cause it's a 4k
Old 11-15-2012, 12:17 AM   #16
gmachinz
Re: Add a tach?
Well, I take back the comment about them being not so desirable-if you wanted to pay the money you can send it in and have it re-faced/calibrated for whatever RPM you want-a friend of mine just got his 1984 factory tach back and it had a burnt circuit board-it didn't need re-faced or anything but wiht a NEW board and calibrated it cost him $160 with shipping both ways-took about a week and a half turn around time-works great now. You could reface it, throw a quartz clock in the lower left corner and call life good!
Old 11-15-2012, 06:33 PM   #17
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Add a tach?
Have you ever come across one?
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-15-2012, 06:36 PM   #18
82ccshorty
82ccshorty's Avatar
Re: Add a tach?
I have a diesel one but how can you tell if it's mecanical
Old 11-15-2012, 06:56 PM   #19
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Add a tach?
Instead of wires connecting to the back of it it has a cable, kinda like the speedometer.
Tony
Old 11-15-2012, 08:10 PM   #20
82ccshorty
82ccshorty's Avatar
Re: Add a tach?
On the tach?
Old 11-15-2012, 08:15 PM   #21
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Add a tach?
That is what we are talking about isn't it?
Tony
Old 11-15-2012, 08:39 PM   #22
gmachinz
Re: Add a tach?
I guess I've never seen a mechanical tach even in the big series trucks.
Old 11-15-2012, 09:21 PM   #23
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Re: Add a tach?
Hey where'd my first comment go mods? I wasn't trying to buy one from him, I just wanted to know if he had one.
Dieselwrencher said he has seen some, im just trying to find a picture of one.
Tony
Old 11-16-2012, 05:34 AM   #24
burb1085
burb1085's Avatar
Re: Add a tach?
Did you see these? http://www.lmctruck.com/NewParts/CC/CCRPT.htm
burb1085 is offline   Reply With Quote
Old 11-16-2012, 06:51 PM   #25
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
Re: Add a tach?
Originally Posted by burb1085 View Post
I sure did! Thanks for pointing them out to me. I need the WHOLE gauge setup, not just the tach since my truck is cursed with idiot lights instead of these nifty gauges that I like so much. I like to keep my truck as OEM original as possible, but if the OEM tach ever goes bad I would consider this aftermarket one.
HIGHWAY BY THE SEA is offline   Reply With Quote
