Old 11-13-2012, 03:42 PM   #1
Jargo
Origional exhaust routing for a 63, 230
Does anyone know where I can buy original exhaust pipe for the a 1963 C10 230???
Or routing diagram for exhaust?
I have tried local dealers, LMC, searched on the web no luck.
I am trying to put the truck back completely original. I have found the muffler and tail pipe although no routing diagrams or anything to have one custom made.
Jargo is offline   Reply With Quote
Old 11-13-2012, 05:09 PM   #2
72step
72step's Avatar
Re: Origional exhaust routing for a 63, 230
I have a 65 C10 230 and I remember the original basically goes straight back and exits just behind the drivers side rear tire. I don't recall exactly how it went over the rear end because I took it apart 15 years ago then my dad got it but never did anything with it but the original exhaust got lost on one of his moves. Right now I'm trying to figure out how to put together some exhaust to keep on a budget. I know oreilly sells 45 and 90 elbows and other pieces. If I could just find me the flared piece for the manifold I could easily set it up to at least behind the cab with my flux core welder. I wish I remembered what the original exhaust does at the rearend. I assume it just curves like a C like most other vehicles. Hopefully someone on here will chime in.......
72step is offline   Reply With Quote
Old 11-13-2012, 05:26 PM   #3
1963c-10
1963c-10's Avatar
I can get pics of my exhaust tomorrow. My 63's exhaust is about as stock as it came. Problem is its raining it tail off outside right now.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-13-2012, 05:31 PM   #4
72step
72step's Avatar
When you get a chance that would be helpful buddy! THanks...
Old 11-13-2012, 08:17 PM   #5
Turkey
Turkey's Avatar
auto zone believe it or not
Turkey is offline   Reply With Quote
Old 11-13-2012, 09:03 PM   #6
Jargo
Thanks for the help
Old 11-13-2012, 09:19 PM   #7
sigshooter
sigshooter's Avatar
Walker exhaust is the brand name Oreilly, autozone and advanced all sell walker exhaust. They are the best for OEM fit pipe and mufflers...
I took these pics and had my local muffler shop do it and it was spot on except OEM is all clamp connections and the shop welded them.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 11-13-2012, 09:21 PM   #8
sigshooter
sigshooter's Avatar
you can look up walker exhaust online at the above mentioned parts stores website. about 200 bucks for all new
1966 Short stepside
1964 long bed
Old 11-14-2012, 12:56 AM   #9
Jargo
Thanks for the pictures, I should be able to get it back to original now.
Old 11-14-2012, 06:14 AM   #10
Sharps40
Try here.
http://www.waldronexhaust.com/
Sharps40 is offline   Reply With Quote
