11-13-2012, 04:57 PM | #1 |
Petroleum User
All 67-72 GMC rad core supports identical?
And, if a 71-72 grille top bar was removed, would it fit with a 68 hood?
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
11-13-2012, 07:26 PM | #2 |
Re: All 67-72 GMC rad core supports identical?
The only thing different I know for sure is the 67-68 has welded nuts along the bottom were you can bolt the splash apron on and the 69-72 does not have that. The only other thing would be some has a hole for your metal condenser lines for A/C and some don't. Yes it would fit but you would have to use a 67-68 top bar. Hope this helps.
11-13-2012, 08:01 PM | #3 | |
Petroleum User
And, I just looked at your awesome stepside! Gorgeous truck. Is that an aftermarket grille?
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto Last edited by 71sierragrande; 11-13-2012 at 08:08 PM. |
11-13-2012, 08:18 PM | #4 |
Thanks I have had the steeper all my life almost. The grill is a orginal 67 that has been rechromed
11-13-2012, 08:21 PM | #5 |
Petroleum User
I thought the 67's had the GMC logo?
11-13-2012, 08:56 PM | #6 |
Check with LMC but I think the core supports for 67/68 were different from 69-72. I don't think that the hood will fit.
From my intel gathering over a couple years, if you want to swap the sheet metal either way, you will need the fenders, hood, and complete grill. Just my $0.02
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
11-13-2012, 09:15 PM | #7 |
It does have the GMCembossed in the grill if you look close.
ole greenie you are thinking Chevy. GMC's use the same fender 68-72 were Chevys are 67-68 and 69-72 |
11-13-2012, 11:21 PM | #8 |
Very well! Indeed, I am speaking of Chevy metal. My ignorance has been exposed! hehe
