11-13-2012, 05:54 PM | #1 |
Wtb rear bench seat parts
Looking for the rear bench seat parts for a blazer....the rear brackets that bolt the seat to the floor
Proud to be IBEW Local 2150 |
11-13-2012, 10:21 PM | #2 |
Re: Wtb rear bench seat parts
I seen some that Morelovethanmoney had listed. http://67-72chevytrucks.com/vboard/s...d.php?t=547501 Page three # 10 & 11
11-13-2012, 10:36 PM | #3 |
After reading your post again I am thinking they are not what you are looking for. The hold down brackets for the front of the rear seat are available new.
http://www.truckandcarshop.com/6072.html Page 19 $ 15.00 pr. |
11-14-2012, 12:53 AM | #4 |
I'm looking for the brackets that go on the rear of the bench seat. The rear "legs"
11-14-2012, 01:24 AM | #5 |
Thanks for the link bluek5. I looked at what morelovethanmoney had listed and it looks like he has the rear legs for the back bench seat that I want. Looks like he's got them labeled pg.3 number 10 and 11. Could you do me a favor and check it out and give me your opinion if they look like the rear bench seat legs?
11-14-2012, 02:27 AM | #6 |
They look like the rear legs to me. The two smaller holes bolt the bracket to the seat the single larger hole bolts to the floor. The hole that is in the middle with the bolt in the picture is for the seat belt. I have a 71 blazer that uses four brackets and a 72 blazer that only uses two. Take a look at this link it is a third row seat out of a suburban I am pretty sure it is the same as a blazer.
http://67-72chevytrucks.com/vboard/s...d.php?t=539764 Hope this helps. Paul |
11-14-2012, 09:10 AM | #7 |
Ok thanks. Ya my 72 only has two legs but the holes are still there to put the other two. I'm thinkin it will look nicer to have all four legs. Plus one of the legs I have now is bent up and I need to replace it
