Old 11-13-2012, 06:13 PM   #1
MikeyMan
Fuel Pump Bolts
Do I need hardened or certain grade bolts to mount the mechanical fuel pump on my small block 350?
Just replaced the fuel pump on my 72 C/10 with 350. Thanks for the tips from the board, the long bolt to hold the push rod trick worked great!
There were allen-head socket cap bolts holding the old pump on. One bolt was longer, with about 6 lock washers as shims/spacers. I figured I'd replace those bolts with some 3/8" stainless steel hex cap bolts. Well, the stainless bolts I had were too short or too long. I ended up using regular standard bolts that were the proper length.
So, what type of 3/8" bolt would be correct and/or recommended to mount the fuel pump to block?
MikeyMan is offline   Reply With Quote
Old 11-13-2012, 06:19 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Fuel Pump Bolts
A fuel pump doesn't put any strain on the bolts... regular bolts are fine.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-14-2012, 06:57 PM   #3
MikeyMan
Re: Fuel Pump Bolts
Thanks for the reply!
My concern was about heat cycles and pressure from the fuel pump lever.
I'd hate to snap a mounting bolt.
